HELP ecm kept buring out #15169278
Old Oct 1, 2010 | 09:30 AM
bob hd19891993's Avatar
bob hd19891993
Default HELP ecm kept buring out #15169278
this is the fourth one in as many years !!! it is a supercharged 1993 with meth!!!
Old Oct 1, 2010 | 10:22 AM
3D-Aircrew's Avatar
3D-Aircrew
Default Check your injectors
Injectors that are shorted out can destroy the driver circuits of the ECM.
Old Oct 1, 2010 | 11:05 AM
surfer93's Avatar
surfer93
What is going bad?
If you leave a bad sensor on the car long enough, it will take out the ECM.
Old Oct 1, 2010 | 02:50 PM
bob hd19891993
don't know what going bad in the ecm but the syn light come on and it's done! i have disconnected the emission control don't need them. all the sencor are fine? i have check the injector accel? and ground!
Old Oct 1, 2010 | 03:13 PM
surfer93's Avatar
surfer93
What is SYN light?
Did you have the EGR stuff programmed out of the ECM?
Old Oct 1, 2010 | 04:30 PM
bob hd19891993
system light! i have tuner c.a.t and have it set low in some high in other so it does not come on?
Old Oct 1, 2010 | 04:35 PM
surfer93's Avatar
surfer93
What code are you getting, when the SYS light comes on?
Old Oct 1, 2010 | 05:03 PM
bob hd19891993
not getting any ! but the one that was there ac code 71 72? i have the connector off and not touching any thing
Old Oct 1, 2010 | 07:39 PM
surfer93's Avatar
surfer93
What is ac code?
You have CCM = 1.0 will be displayed on the dash
ECM = 4.0
ABS = 9.0
Which system generated the 70 and 71?
Old Oct 1, 2010 | 09:17 PM
bob hd19891993
scan tool autoxray
Old Oct 1, 2010 | 10:13 PM
surfer93's Avatar
surfer93
Without a xref, those codes are useless.
Put a paperclip in the top right and bottom left ALDL connector and turn the key to ON.
Read the codes and come back and tell us, also get a FSM. It will save you 10 times what you pay for it.
Old Oct 2, 2010 | 12:14 PM
bob hd19891993
thank everyone i moved some ground around. check every thing again!the ac sencor is not hook up because it broken!! that's why iam getting the code!!! it died on the way home last night don't know why but it started back up. no sym light this time no codes?
Old Oct 4, 2010 | 09:32 AM
bob hd19891993
update found a short in the coil? coil went bad would that take the ecm out
To HELP ecm kept buring out #15169278
