lowering/half shaft question
Old Oct 2, 2010 | 01:58 AM
ironvapor's Avatar
ironvapor
Default lowering/half shaft question
I have seen threads that discuss when lowering a Corvette keeping the half shafts level. Is there a reason for this? In the stock configuration the half shafts are angled slightly higher at the differential. If a car was lowered so the half shafts were angled slightly lower starting at the spindle side upward to the differential what would be the negative consequences if any? Would it do some harm to the differential? The u-joints? If any one knows the answer to this I would appreciate you clearing it up for me.
Old Nov 7, 2010 | 01:22 AM
Charleston2012's Avatar
Charleston2012
Supposedly it needs to be level. But if you go past a certain point the half shaft wont be level. I am at 1 3/4 lower than factory with 315's and it is not level. So, the question needs to be answered, and I hope someone does answer, with a real answer and not tribal knowledge.
Old Nov 7, 2010 | 01:39 AM
eatmydst1234's Avatar
eatmydst1234
I believe, half shaft are the strongest when they are level.
Old Nov 7, 2010 | 02:14 AM
rodj's Avatar
rodj
U-joints
http://forums.corvetteforum.com/1564310625-post10.html
To lowering/half shaft question
