Installing Accel Thruster on 85 / Harness question.
If you have put a Thruster or Gen 6/7 unit on your C4, could you tell me how you routed the wiring harness?
I have a Thruster and am preparing to do the install but picking the path through the firewall into the the dash area looks tricky.
Any advice / suggestions?
I plan to put the module behind the passenger side dash panel where the MAF relay / burnoff module was. I removed the bread loaf years ago and replaced it with a flat panel that is easy to remove.
