Can't figure out my idle problem
Old Oct 4, 2010 | 07:08 PM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
Default Can't figure out my idle problem
92 LT1: Overall she runs great, but.........sometimes after restarting when it's at operating temperature, the idle sits at 1500-1800 RPM for a minute or two, and then drops to where it should be (600-700). Sometimes it will suddenly idle at 1000RPM in gear and then after a few minutes go back to normal. I've removed and cleaned the TB including the IAC orifice, and just put in a new IAC. I'm pretty sure it's not a vac leak, because I would expect the problem to happen every time and not just randomly.
Does anyone have any suggestions as to what to look for?
Old Oct 4, 2010 | 09:20 PM
C4happy's Avatar
C4happy
Does it idle smooth or is it ruff if it is ruff it could be a sticky egr valve some of those electronic ones will stick open causing a low ruff idle.
Old Oct 4, 2010 | 09:24 PM
87 vette 81 big girl's Avatar
Does the Check Engine Light ever come on ?
Old Oct 7, 2010 | 07:34 PM
92ragtop's Avatar
92ragtop
Been away for a few days........
No, the idle is normally totally smooth. No wandering or roughness at all. Check Engine never comes on either.
Old Oct 7, 2010 | 07:56 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
Is the throttle sticking? Try closing the throttle by hand when its idling high.
Old Oct 8, 2010 | 09:29 PM
pcolt94's Avatar
pcolt94
I would get a scanner and see what the counts are doing. See if RPM follows the counts being programmed. The IAC is driven by the ECM and very possible the ECM is bad regardless of what the counts say. I would also check the respective pin connections between the IAC and ECM.
Old Oct 9, 2010 | 04:44 PM
MaSTeRofDZaSTeR's Avatar
MaSTeRofDZaSTeR
From: "Drive like Hell, you'll get there faster." Tucson AZ
If the LT1 has one too, have your TPS(Throttle Position Sensor) checked. Not many mention it up here, but mine actually went apesh1t on me in my '90 some time back and caused idles in that range with strange sudden shifts.
Old Oct 9, 2010 | 04:52 PM
tehcarguy's Avatar
tehcarguy
The TPS can cause the engine to idle strange? I did not know that...
Old Oct 9, 2010 | 06:05 PM
desertmike1's Avatar
desertmike1
This could also be a IAC valve issue...at this point I would use the FSM fault tree.
Old Oct 10, 2010 | 12:42 PM
92ragtop's Avatar
92ragtop
Thanks for the feedback everyone.
Old Oct 10, 2010 | 01:38 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Old Oct 10, 2010 | 05:47 PM
sailorsteve's Avatar
sailorsteve
Have you checked for codes? It's possible for a code to set with the service light off.
Old Oct 10, 2010 | 09:27 PM
95BLKVette's Avatar
95BLKVette
You put in a new IAC and if I remember correctly you have to have the ECM re-learn the new IAC, This can only be done with the original GM scanner. I know because I bought one specifically for this purpose
Old Oct 11, 2010 | 10:04 AM
sailorsteve
The '92 FSM does not call for use of a Tech tool when replacing the IAC. See page 6E3-C2-15 and elsewhere in the 6E3 section. Be careful to use the correct 6E3 section, for LT1 and not LT5.
Old Oct 11, 2010 | 12:12 PM
92ragtop's Avatar
92ragtop
Dang. I've only got Volume 1 of the FSM, and 6E is in volume 2. Is there something more to be done besides the reset procedure?
Old Oct 11, 2010 | 03:17 PM
pcolt94's Avatar
pcolt94
I agree there is really no reset procedure where a tool is required. If you want to start from square 1, disconnect the battery and that will reset the ECM. The ECM monitors the RPM and adjusts the counts of the IAC for a targeted RPM given those conditions from external inputs (engine temp, outside temp, A/C, etc) to the ECM. The ECM will find the correct setting (IAC counts) for condictions, for a pre determined RPM setting (this is the learning procedure).
This is true provided the ECM is working correctly.
Old Oct 11, 2010 | 03:19 PM
Redeasysport
To Can't figure out my idle problem
Old Oct 11, 2010 | 04:24 PM
sailorsteve
Codes?
Old Oct 11, 2010 | 06:52 PM
desertmike1
Codes?
This information is probably covered in Vol 2
Old Oct 12, 2010 | 08:09 AM
sailorsteve
You can read codes without a scanner from the ALDL connector under the dash, above the gas pedal. The search function on this forum will tell you how. If you get a code, post it and I will post the page in the manual that has the diagnostic tree.
