computer.
Old Oct 5, 2010 | 02:49 PM
Blame's Avatar
Blame
Default computer.
Is there a way to install a 93-96 computer into a 90? Then have it program to work for my vette?
I ask because I like to start upgrading to the obo2 so I can use the hand held tech. I would love to buy a vette with the obo 2 in it but I got the year I wanted. So, can anyone help me with the above question.
Old Oct 5, 2010 | 05:45 PM
Blame's Avatar
Blame
There got to be someone who know something. TTT
Old Oct 5, 2010 | 06:01 PM
toptechx6's Avatar
toptechx6
I'm having trouble understanding what you want to accomplish, there are scan tools that will function with your OBDI ECM as well as cables and software to data log to a laptop.
The only C4 computer that is OBDII compliant is the 96, but for it to function and provide misfire and cat efficiency information the 96 engines also have a crankshaft position sensor and 4 O2 sensors. Your 90 has no crank position sensor and only a single O2 sensor, it is a speed density system with batch fire injectors, the 96 is MAF with sequential injection, my guess is that the conversion you want is impractical if not impossible.
Old Oct 5, 2010 | 06:39 PM
rodj's Avatar
rodj
For starters ,the LT1 with the Optispark has a completely different spark system so you would have to work around that first.
What is the hand held going to give you that a laptop and software as used on the earlier ECM's won't
Old Oct 5, 2010 | 06:50 PM
toptechx6's Avatar
toptechx6
The more I think about this the more I think he is talking about the Hypertech programmers used on 94 and up vehicles.
Old Oct 5, 2010 | 08:00 PM
Blame's Avatar
Blame
OK now we getting somewhere. So, what kind of program do I need for my laptop to work on my vette?
Old Oct 5, 2010 | 08:04 PM
James93LT1's Avatar
James93LT1
Veteran: National Guard
Datamaster for logging, and tuner cat for the tune.
Old Oct 5, 2010 | 08:08 PM
Blame's Avatar
Blame
can these programs read codes too?
Old Oct 5, 2010 | 08:11 PM
James93LT1's Avatar
James93LT1
Yup, datamaster.
Old Oct 5, 2010 | 08:29 PM
rodj's Avatar
rodj
All you need is a paperclip to read codes
http://www.corvettebuyers.com/c4vettes/codes.htm
Old Oct 5, 2010 | 08:30 PM
Blame's Avatar
Blame
Yup, datamaster.
so I need to get both for all round work then. How do I go about buying these programs and how much?
Old Oct 5, 2010 | 08:32 PM
Blame's Avatar
Blame
that maybe true but they just tell where to look not what part is bad. like my FX3 say the system is bad when it was just a bad shock.
Old Oct 5, 2010 | 09:02 PM
James93LT1's Avatar
James93LT1
For logging (to see what is going on and find faults)
http://www.ttspowersystems.com/DataMaster.html
http://www.moates.net/datalog-and-reflash-c-97
or
http://www.akmcables.com/
For Tuning (adjust engine parameters)
http://www.tunercat.com/
http://www.moates.net/gm-obd1-pre1996-c-64.html
Old Oct 5, 2010 | 09:14 PM
Blame's Avatar
Blame
thank you
Old Oct 6, 2010 | 03:58 AM
toptechx6's Avatar
toptechx6
No paperclip, scanner or software will tell you what part is bad, DTC's or Diagnostic Trouble Codes are just that, a starting point for diagnosis. The next step in the process is to follow the steps in the Factory Service Manual for the code retrieved to isolate the root cause of the problem. Scan tools and software do have the ability to read the data stream which can certainly help with diagnosis unlike simply retrieving codes using a paperclip.
You should also understand that all consumer grade tools and scanning software will only read data from the ECM/PCM. You will need a Tech 1, Tech 2 or other professional grade scan tool to access data from ABS, FX3, or CCM controllers.
Old Oct 10, 2010 | 05:49 PM
alrosenzweig's Avatar
alrosenzweig
St. Jude Donor '11
Very helpful Top Tech
To computer.
