stupid spark plug question
Old Oct 8, 2010 | 08:56 PM
JAKE's Avatar
JAKE
Originally Posted by joshwilson3
What AFPR was it? I've got ordered a TPiS AFPR.
I have heard the vacuum nipple thing coming loose on these. I believe that nipple is just screwed in. I plan to remove that and tighten it down with some blue thread lock on the threads.
I've also read it is a good idea to put blue thread lock on the bolts that bolt the hat down on the regulator. Before I put the plenum back on. I plan to turn the key "on" and raise the pressure up to something like 55 psi to make sure the regulator doesn't leak before I put it all back together.
Aeromotive.
Jake
Old Oct 8, 2010 | 09:02 PM
JAKE's Avatar
JAKE
Ryan tried doing it that way but couldn't get a reading until he actually fired the engine. Then he saw that he'd adjusted the pressure way too high and had to back down on the adjustment screw.
Just what happened with his install.
Jake
Old Oct 31, 2010 | 09:10 PM
steverichmond's Avatar
steverichmond
Originally Posted by lt4obsesses
It's not really that tough. Yes there are couple of plugs that require some true manual dexterity. The real secret is to not be in hurry. To change the wires, if you go ahead and remove all of the things in your way first, mainly the belt tensioner, the ac/alternator assembly, the asr or at least the plastic cover and emission hoses, you have a pretty straight shot at most everything. While it seems like a real pia, it just takes time. It takes more time getting to the plugs and wires than it does to actually change them. The good side of this, is you get to clean parts of the engine bay you normally can't reach.
Great advise. I just finished changing the wires and plugs on my LT1. It certianly isn't something you can in a rush! I had trouble getting the wires onto the distruibutor coming from the top (drivers side). I ended up sliding them onto rotor cap from underneath the car. I wish I has slimmer hands. It now has a miss but I'm to tired and frustrated to mess with it anymore today. I suspect, I've got a problem with one of the wires not pushed up good on the distributor. I'll dig back in later this week and find my grimlin.
Steve
Old Nov 1, 2010 | 03:23 PM
96_vette's Avatar
96_vette
My weapon of choice are the TR-55's from NGK, and when i'm done, some of these........
http://www.drugsupplystore.com/catalog/05ba_1_186_1.JPG
Old Nov 4, 2010 | 06:40 PM
steverichmond
I found the miss, it was a cracked #7 plug. Running smoothly again. The LT1 is one tough engine to tune up considering my skill set.
Old Nov 7, 2010 | 07:29 PM
steverichmond
Correction! I finally took it for test drive and it seems to run good except after it warmed up it seems to miss a little when idling and in drive. I've checked all my wire connections and they are good. How can I determine which cylinder is missing?
Steve
Old Nov 8, 2010 | 01:26 PM
JAKE's Avatar
JAKE
Connect a vacuum gauge to the engine. With it idling see if the needle holds steady. You'll be looking for a possible vacuum leak.
On a very dark night, check carefully for any spark arcing to ground. Look VERY carefully since some are hard to see.
Jake
Old Nov 8, 2010 | 04:18 PM
steverichmond
Great suggestion! I'll try it.
Old Nov 8, 2010 | 04:20 PM
steverichmond
Anyone care to share tips on replacing the coil wire on a LT1? Looks like the sp gotta come off. Am I right?
Steve
Old Nov 8, 2010 | 06:07 PM
JAKE's Avatar
JAKE
Anyone care to share tips on replacing the coil wire on a LT1? Looks like the sp gotta come off. Am I right?Steve
It's a TIGHT FIT but with enough effort you can do it.
Lost me on the "sp" though.
Jake
Old Nov 8, 2010 | 06:25 PM
steverichmond
oops, typo ment to say wp for waterpump. Typing is not one of my strong points. I guess I need to look at it again, I did not see any way to get the coil wire to connect to the opti.
Steve
Old Nov 8, 2010 | 07:04 PM
JAKE's Avatar
JAKE
Come in from the Driver's side of the engine; between the water pump and block. Tight, tight, tight.
Jake
Old Nov 8, 2010 | 09:18 PM
  #33
steverichmond
Boy were you ever right. TIGHT TIGHT TIGHT! But I got it. I'm so glad the tune up is behind me. Thanks so much for your help.
Steve
Old Nov 8, 2010 | 09:25 PM
  #34
F1Fan's Avatar
F1Fan
It helps to have small dexterous hands in getting the wires on and off the opti on the drivers side. Hell hole is right IMO...
