brake and ignition problems 1990
Old Oct 6, 2010 | 08:20 AM
jeffp1167's Avatar
jeffp1167
Default brake and ignition problems 1990
my brakes seem horrible on my 90. pedal very soft and feels like it can go to the floor. ABS light on from second car is started .... I know nothing about this abs system so any help is appreciated
second problem ... when ignition key turned back no accesory power for like the radio ... or is this normal?
Old Oct 6, 2010 | 11:00 AM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
Start by checking the brake fluid level.
Old Oct 6, 2010 | 08:21 PM
jfb's Avatar
jfb
Your brake system needs checking out. You also need the help of an ABS tester, most GM dealers have a tester. Ign sw has to be in run for the radio to work.
Old Oct 7, 2010 | 08:51 AM
jeffp1167's Avatar
jeffp1167
ok I have a 97 camaro and when I turn the ignition backwards from off position the accesory power comes on and radio can be used. So what my vette is doing is normal? Ive just never seen this before.
the car is full of brake fluid however the brake sensor on the master cylinder is unplugged because the pigtail is damaged
Old Oct 7, 2010 | 09:37 AM
jfb's Avatar
jfb
I have an 87 vette and can't recall if there is an accy position on the ign sw, I don't think there is.
Old Oct 7, 2010 | 10:58 AM
0Paul Ruggeri
Former Vendor
If the fluid level sensor isn't working the ABS light will come on. If the pedal sinks to the floor under light pressurer, the master cylinder is leaking internally and needs to be replaced.
To brake and ignition problems 1990
