85 corvette 9th injector
Old Oct 6, 2010 | 06:20 PM
smile5's Avatar
smile5
Default 85 corvette 9th injector
Hello, I ahve an 85 corvette that will not idle until it warms up, someone told me that 85 corvettes have a 9th injector that helps with cold starts, but I am unable to find it on the motor. I was told that it was suppose to be on the drivers side fuel rail, did not see one. Thanks John
Old Oct 6, 2010 | 07:29 PM
vetteoz's Avatar
vetteoz
Nothing to do with idle; only injects extra fuel while cranking ( when coolant temp below a certain temp )
If it was faulty and leaking ( common ), then engine would be running rich all the time which would make hot idle worse
Quite possible a PO it removed it .If operational should have the steel line shown running to rear of fuel rail
