Frustrated 89 owner - will not run
Took the 89 out of storage about two months ago - fired right up with no problems. Drove a little over 30 miles, stopped for lunch - came out and would not start, engine would turn over but not kick in. Ended up towing home and have been working the issues since then. Car would start if we shot some ether into the intake. Would not keep running.Decided to do a major tune-up: replaced the following - new MAF, new plugs, new wires, new rotor, rotor cap, ignition coil, new 02 sensor, new pcv valves, new egr valve, rebuilt gas regulator, new fuel filter (drained all the old gas and replaced with new), cleaned plenum of carbon buildup, checked injectors and replaced the seals. Put it all back together and.......................
Tried to start - no go - would run a bit on ether.
Then checked all the electical connections - all good, to include all the fuses - tested each circuit. Noticed a lot of heat from ECM under dash - so we replaced that as well.
Did a compression test - no problems
Checked all the vacumm lines - apparently the previous owner decided to jury-rig the lines. (this car ran great for the 10 years I have owned it. Some vacumm lines were blocked off and some were wide open. Now we are running the vacumm lines as they should be done.
We can get the engine running but real rough and not for long. You can understand why we are frustrated. The guy doing the main work (most of it) is GM trained (now retired) and has all the tools and diagnostic tools we need. Has him at a mindblock.
Only line we cannot find a diagram on is for the brake booster - not sure from where it is to come from??? Local Chevy garages will not help out even for a few questions.....
I do have a diagram showing the routing of the vacumm lines in the engine compartment but not for the brake booster. Any help appreciated.
ALSO - any ideas as to where to look/fix/replace next??????
Any stored trouble codes on the computer?
If your running the stock '89 non ethenol compliant fuel injectors those things have a mind of their own and have caused many problems for their owners. Long story short: the injectors may ohm out OK and fire with an injector bench tester but the ECM won't trigger them under normal circumstances.
My recommendation is change the fuel injectors out for an ethenol compliant set.
Your engine ran with starter fluid, this tells you that you have spark but no fuel! First measure fuel pressure on the shraeder valve on the end of the right fuel rail. It should be 35-42 psi and it should hold up during cranking to start and it should hold up for at least a half hour after the ign is off. Fast leak down tells you that you have leaky injector/s or a defective check valve on the fuel pressure regulator. You can measure the resistance (16 ohms) of the injector coils, but that will only find gross coil errors. The definitive electrical test on injector coils is done with an impedance bridge which measures the inductance and the Q of the coils. An ohmeter cannot find a turn to turn short, but a bridge can and injectors will not work with a turn to turn short! Also, the injectors MUSY spray fuel and the only way to tell that is to look at them when they are spraying fuel.
If not, your injectors aren't actually moving internally. Check for a bad engine ground.
The fact that it started at all with a shot of ether into the intake clearly indicates a fuel problem. And the fact that it won't stay running after that might also be related. If you have not already done so I would be curious to see the injector spray patterns. The only way to see that is to either remove them to have them bench tested and pulsed under pressure or to remove the runner & plenum and suspend the fuel rail while dipping each injector into a glass jar with fuel lines still attached and tach wire on dist cap connected. You can do this with some fuel line fittings and rubber hose with clamps between the rail and car's lines.
Remember that too much gas will also prevent a car to not start when hot but will still start with some carb cleaner or starter fluid into the intake.
Thanks again to all
always a good idea
