help with harmonic balancer
Old Oct 8, 2010 | 10:08 PM
daniel5625's Avatar
daniel5625
Default help with harmonic balancer
okay, i have a 93 lt1, will the harmonic balancer only go on one way? because the way it was marked the bolt holes dont line up, i also stripped one of them and thinking of just putting 2 bolts in. should it be fine with only 2?
let me know, thanks!
Old Oct 9, 2010 | 04:56 PM
capricelimburg's Avatar
capricelimburg
The holes will only line up one way, if they aren't lining up rotate the balancer 120 degrees and try again. All 3 bolts need to be in or it will be severely out of balance (=bad)
Old Oct 9, 2010 | 04:58 PM
tehcarguy's Avatar
tehcarguy
IMO leaving only 2 bolts in would be a bit dangerous.
Old Oct 10, 2010 | 01:51 AM
ZBRA's Avatar
ZBRA
You need all three bolts. You now need to pull the hub off the crank and replace it.
Old Oct 10, 2010 | 09:22 AM
STL94LT1's Avatar
STL94LT1
Have you tried retapping the stripped bolt hole?
Old Oct 11, 2010 | 04:23 PM
JAKE's Avatar
JAKE
I'd definitely chase the bad threads and re-install ALL THREE BOLTS. Tri-angling is the key and GM uses it for many of it's brackets/mountings, braces, etc.
You could also go up a very small amount in bolt size - maybe to a metric after a re-tap - in order to still be able to run THREE BOLTS. If there's any difference in the weight of the bolts it'll be negligible.
Either way, I strongly recommend installing THREE BOLTS.
Jake
Old Oct 11, 2010 | 06:48 PM
samsonb's Avatar
samsonb
If it is the original balancer. That would be a good time to go ahead and replace it as it is a wear item.
Old Oct 11, 2010 | 08:41 PM
94vettelover2's Avatar
94vettelover2
If its in great shape & the hole is completely fubared,drill out & install a Heli-coil insert & install same size bolt.One Heli-coil shouldn't cause a issue.Or you could drill everyone & Heli-coil all 3 so the rotating weight will all be the same at each bolt hole.Alot cheaper than a new balancer
Old Oct 15, 2010 | 10:01 AM
STL94LT1's Avatar
STL94LT1
The threads are in the hub, not balancer.
To help with harmonic balancer
