Cam going flat?
Old Oct 11, 2010 | 11:49 PM
mcm95403's Avatar
mcm95403
Default Cam going flat?
I'd like everyones opinion on my old stock cam. I did my Renegade install this weekend and now feel like I should have just stopped when I saw the cam lobes that I could see through the oil return holes in the valley. The lobes were all polished VERY shiny, no Parkerization left with some ugly looking ridges/grooves.
In the picture below you can see that some of the lifters are going down flush with the tops of the lifter bores. It's also pretty obvious when cranking the engine around to adjust the valves that some of the valves are getting significantly less lift than others. I'm pretty convinced that the cam is flat but I can't get back to tearing into the eninge till this weekend. In the mean time, I'd like opnions from those with extensive cam experience regarding the hieght of the lifters in the bores. Note the #6 exhaust lifter and the #8 intake lifter especially.
Sorry for the huge picture but I wanted to give as much detail as possible.
Old Oct 12, 2010 | 12:53 AM
neverendingprojects's Avatar
neverendingprojects
From what I have seen my Small block chevy past, (MANY ENGINES) everything appears to look OK here..
It is not uncommon at all for the lifters to sit a little lower in one bank of cylinders, then the opposite side... If you cam was actually flat, none of the lifters would be up that high!
On the other hand, looks like your already about 1/2 way there if you wanted to swap out the cam!
Old Oct 12, 2010 | 03:04 AM
lt4obsesses's Avatar
lt4obsesses
I'm not positive, but I really don't think one can get a real good look at the cam lobes through the oil return holes. I know that when I had a lifter noise and we replaced lifters, the best visual came from looking through the lifter hole directly down on the lobe. Using a flashlight you should be able to see if the lobe is being worn down. It is possible, especially if those are tappet lifters. Of course, the only real way to be positively sure is to use a dial indicator and measure the precise lift of each lobe.
If I'm not mistaken, you have flat tappet lifters. These are also prone to wearing down. Did you pull the lifters to inspect while you had the valley exposed?
Old Oct 12, 2010 | 07:43 AM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
The reason you see some of the lifters high in the bore and others low, is because you have cam lobes.
The lifters that are low in the bore are sitting on the base circle of the cam, allowing the valve to close.
The lifters that are high in the bore are up on the cam lobe, in order to open the valve.
Old Oct 12, 2010 | 09:11 AM
383vett's Avatar
383vett
Compare the lifts with a dial indicator. Easy to do and pretty inexpensive.
Old Oct 12, 2010 | 10:55 AM
mcm95403's Avatar
mcm95403
I have a dial indicator and will use that this weekend.
I think the point you guys are missing so far is that some of the lifters are on the heel of the lobe and riding much lower in the bores than other lifterw that are also on the heel. Obviously, as the cam rotates and the lifter moves up the ramp and onto the nose of the cam lobe the lifter is going to rise. But my concern is the heel side being worn away (as well as the rest of the lobe) and the lifter not getting all the motion it should.
Old Oct 12, 2010 | 11:57 AM
2012 coupe's Avatar
2012 coupe
Default cam
I am replacing my org engine, 286,000 miles because the cam lobes have flatten out and the bottom of the lifters are worn. I am putting in a new 427 LT-1 I have had in my garage for a while. Just wanted to see how far the org engine would go.
Old Oct 12, 2010 | 12:13 PM
powerpigz-51's Avatar
powerpigz-51
It seems to me that any wear or "flattening" would occur on the lobes themselves. If you had enough wear to affect the base of the cam, I would expect some kind of driveability issues. A dial indicator will tell you for sure, but I would expect some wear to occur and some differences between each lobe. I would try to measure at the top of the lifter. It does concern me that you can eyeball some of this. Anyways, good excuse for a new cam to go with your new manifold. A Lunati Voodoo 101 would be sweet with that combo.
Old Oct 12, 2010 | 12:25 PM
mundo's Avatar
mundo
Mark,
Just rip out that weeny L83 and put in a ZZ4 crate engine. Put the Renegade on the ZZ4. It'll whip C5 ZO6s. It's rated 355 HP with about the same torque.
Old Oct 12, 2010 | 01:25 PM
ch@0s's Avatar
ch@0s
Originally Posted by mundo
Mark,
355HP at the crank with no accessories and a carb.
Old Oct 12, 2010 | 01:34 PM
mundo's Avatar
mundo
You can put other induction on a ZZ4. Doesn't have to be a carburetor. Besides the 650 on the crate engine isn't pulling what EFI could.
Top Flight Corvette in San Diego replaces L98 engines all the time with ZZ4s. A tuned right ZZ4 will produce nearly 400 hp at the fly wheel. I've talked to him about a ZZ4 in my '92. Jerk out the LT1 with opti, insert a ZZ4 with '91 ECM. He says he's done it before. Get more HP, TQ and no opti problems. The HEI distributor will fit under the hood because it does on a '91 (same hood).
Old Oct 12, 2010 | 02:49 PM
ch@0s's Avatar
ch@0s
Interesting.. do they put in a different cam and and or port the heads? From what I understand the 113 heads won't make that much horsepower without major porting. A late L98 and ZZ4 have the 113 heads.
With a CC502 a bigger cam then the ZZ4 113 heads and a HSR intake my car only made 268 Hp. I think it would have made more. But I dough I could have got another 70hp/400CHP .
Old Oct 12, 2010 | 03:52 PM
mtwoolford's Avatar
mtwoolford
pull the lifter; if the bottom of the lifter is obviously damaged, even if only worn concave, the cam lobe is bad also. and vice versa
Old Oct 12, 2010 | 04:41 PM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
Mark,
OR
Run a 383 with a CF and still beat the C5s. LOL Ask me how I know that. Ben73 is living proof that a CF 383 will kill even a mildly modded C5 coupe up to model year 2004 and give a 2005 a good run in stock config.
Old Oct 12, 2010 | 05:58 PM
mcm95403's Avatar
mcm95403
Good point, althought I hate to pull the intake after I just got it on there...........
Easy way to know though.
Old Oct 12, 2010 | 06:32 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
MCM
Wow, you have made a ton of progress on your car in a short time. Its going to be like new. Have you figured how much you have in it so far? Are you going to do anything to that Sears and Robebuck house paint job on your vette?
Mike
Old Oct 12, 2010 | 06:56 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Mark,
No way Jose' that 355 is at crank with a carb. No way it will touch a Z06, even an early one. Why do you keep posting crap like this.
To Cam going flat?
Old Oct 12, 2010 | 07:22 PM
mcm95403's Avatar
mcm95403
Originally Posted by CorvetteMike2004
MCM
Mike
I'm already scared to add up what I've spent. Between tires, all the J55 brake parts, the intake, the Z-51 rack, Edlebrock rear shocks (still need to get the fronts), assorted small parts from the local Corvette Clinic, roller rockers, Hella headlights, mufflers, well, you get the idea.
Hasn't been cheap, but I love the way the car drives and so far everything has been a good improvement from what it was.
Now if I can just sort out this little problem, things should be good.
Old Oct 13, 2010 | 02:37 AM
Pwnage1337's Avatar
Pwnage1337
You should just pull your motor and build a motor with a roller cam. Stick your CFI on it and be good to go. Should only take you a few hours
Old Oct 13, 2010 | 08:03 AM
Pete K's Avatar
Pete K
I agree. This will tell you exactly what each lobe lift is, and allow you to confirm that all 8 intake lobes, and all 8 exhaust lobes are the same.
Multiplying by 1.5 will tell you the valve lift, and this can be compared to the stock specs in your manual.
Based on all the posts I see above, the corvette world seems to think you need a new motor, or upgraded.
Cams have been going flat for years, and in the right situation cam replacement can be a feasibly repair option. I sell engines, and don't think you should let popular opinion sway you that way, until diagnostics prove otherwise. Always entertaining to watch people make recommendations to spend someone else money.
