1995 rear leaf spring trouble...
Old Oct 12, 2010 | 01:04 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
Default 1995 rear leaf spring trouble...
Anyone have a rear fiberglass or (composite) spring split/crack/splinter...etc? What did you replace it with?This is the second time it has happened
Old Oct 12, 2010 | 07:41 AM
PDQUIK95's Avatar
PDQUIK95
From: Portsmouth Virginia 396LT4 435RWHP/400RWTQ Best so far 11.26 @ 123mph
Yes, I replaced it with a VBP sport spring.Thought splintering was the reason for cars drivers side list but turns out it wasn't.
Rick
Old Oct 12, 2010 | 10:06 AM
anciano's Avatar
anciano
Not rear, but front. Will replace it next week with a spring obtained from someone on this forum. Two broken ones seems unusual from what I have seen here. GM's excuse for damaged front springs (engine cleaning solvents) doesn't apply to the rear, and in any case my experience with epoxy resin fiberglass has never revealed a solvent that in brief exposure will damage anything but the very surface of the glass, certainly not cause cracking deep within the structure like on my spring. (If, in fact, the resin they used IS epoxy. The FSM has an extensive list of various "plastic" parts and what materials they are made of but doesn't include the springs in that list. They are described as "fiberglass" in various places in the FSM, but that doesn't tell you anything.) Maybe they used different resins at different times and that is why some delaminate and crack and others don't.
In any case I wonder where GM sourced these springs or if they laid them up themselves. There are many ways to screw up hand-laid fiberglass, as many boat owners can tell you.
Old Oct 14, 2010 | 03:40 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
Thanks for the replies guys....any more responses are welcomed
To 1995 rear leaf spring trouble...
