C4 Upper Front Control Arms
Old Oct 12, 2010 | 09:02 PM
Mr. Wizzard's Avatar
Mr. Wizzard
C2 of Year Finalist (track prepared) 2019
Default C4 Upper Front Control Arms
Is there a difference between the '80's and '90's upper control arms for the front suspension?
Old Oct 12, 2010 | 09:08 PM
COPO's Avatar
COPO
yes
Old Oct 13, 2010 | 06:42 AM
Mr. Wizzard
Can you tell me what the difference is?
Old Oct 13, 2010 | 08:32 PM
COPO's Avatar
COPO
bolt holes and length
Old Oct 13, 2010 | 08:54 PM
Mr. Wizzard
The reason I'm asking is because I have a new Mongoose Grand Sport replica: http://www.theoldone.com/grandsport/...grandsport.htm.
There are already a number of pieces on the car that I have fabricated in an effort to make it (closer) to the original cars in appearance.
The next item on my list is narrowing the car's front tread-width a couple inches to get more of the front tire under the fender flares. I will either build some fixtures and fabricate some upper and lower control arms to do the trick, or move the mounting points for the control arms farther inboard.
In looking at some adjustable upper control arms, I noticed that there was a difference between the early and late ones. I'm thinking that if the early ones are shorter, I might be able to swap in a pair and avoid the fabrication work.
My next question would be about the lower arms....are the early ones shorter than the late ones?
Obviously, if I can simply purchase a set of the earlier pieces, it would save me time and work.
I appreciate all the help I've already received on these forums. With my limited experience with Corvettes, the advice has been priceless.
Old Oct 13, 2010 | 09:14 PM
COPO's Avatar
COPO
lower spindle upper are all different. the later have taller spindles which is better IMO. later are about 3/8 wider or so. What frame are you using?? To narrow suspension takes more than just moving mounting points. You need to kno where to place them!
Old Oct 13, 2010 | 10:02 PM
Mr. Wizzard
The chassis is the Mongoose 4" tubular unit that's standard issue in their Grand Sports.
I have access to a surface plate for mounting the chassis and measuring all relavent suspension pick-up points. We also have equipment for measuring bump-steer, so I'm fairly confident that we can maintain the current roll-centers with the mods.
If I don't rework the suspension to narrow the tread width, the other option I've considered is to CNC some wheels from billet with a different offset that have the Halibrand look....but then I'll need to do a matching set for the rear as well....
Old Oct 13, 2010 | 10:25 PM
COPO's Avatar
COPO
are you wanting a deeper wheel in the front or just move the entire wheel in? what wheels do you have and what brakes?
Old Oct 14, 2010 | 06:48 AM
Mr. Wizzard
I would like to move the wheel/tire inboard by approximately one inch per side, so the wheel center would need to come outward relative to the rim itself. The brakes are currently late-model C4's.
http://www.theoldone.com/grandsport/article/81.jpg
To C4 Upper Front Control Arms
