TB part 2
Old Oct 15, 2010 | 03:02 PM
Blame's Avatar
Blame
Default TB part 2
Ok, I got all new sensor on the the intake and TB. The TPS is giving me a read from 39-45 if I move it up and down. I can't get it to go higher.
I put a long tube in the the IAC hole to cut down the volume and I got a idel speed of 500-900 rpm. The TB is a BBK 58mm brand new plus all new gaskets.
OK, the question.
1: did I get the wrong TPS for the low voltage?
2: since I did get a bigger TB do I need to have the computer reprogam?
Old Oct 15, 2010 | 08:52 PM
tehcarguy's Avatar
tehcarguy
You are supposed to rotate the TPS.
No, the computer doesn't have to be reprogrammed.
Old Oct 15, 2010 | 10:42 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Old Oct 16, 2010 | 09:30 PM
Blame's Avatar
Blame
My TPS does not rotate. It has fixed holes with the right size hole for the screws to fit and not move.
FYI people not all C4 have the TPS that moves like on the LT1 and up. So please do not keep telling me it rotates or moves because on a L98 it does not unless you got the one for the LT1.
Old Oct 16, 2010 | 09:32 PM
Blame's Avatar
Blame
Originally Posted by GREGGPENN
It was sucking in way to much air and the IAC could not stop it all. With this tube in place it cut the volume of air down and gives me a better idle again.
Old Oct 16, 2010 | 09:42 PM
Road Agent's Avatar
Road Agent
Old Oct 16, 2010 | 09:48 PM
Blame's Avatar
Blame
Originally Posted by Road Agent
Hey 800 rpm at a red light is better then 1500rpms at a red light. had people looking at me thinking Im going to drag race them or something.
Old Oct 17, 2010 | 12:53 AM
Calderone's Avatar
Calderone
You might have a vacuum leak if you have a 1500 rpm idle
Old Oct 17, 2010 | 01:07 AM
tehcarguy's Avatar
tehcarguy
ok, I should have been more specific. You move the TPS back and forth to obtain the right voltage.
Old Oct 17, 2010 | 01:46 AM
Calderone's Avatar
Calderone
Does not move or rotate ?
How do you adjust it ?
Is my 87's L98 Special then ? mine does rotate !
Old Oct 17, 2010 | 01:57 AM
Pwnage1337's Avatar
Pwnage1337
You are wrong, my 85 TPS rotates. Check your facts
Old Oct 17, 2010 | 04:13 AM
Calderone's Avatar
Calderone
i see now, there is no way we know it was a '90
He names L98 only
Everyday you learn something new !
i didn't know it !
Is it better to have a fixed TPS ?
what if we use a '90 tps on an earlier model,or it has to do with non-maf cars ?
To TB part 2
