It will work if the camaro had a LT1 in it. Part number on it should be 16159278.
Just remove the camaro memcal, and install the Corvette memcal and you should be good to go.
I know it works on 94/95 cars so it should work for you as well.
Not sure though if memcal has to be swapped or not? I know with 94/95 you can just plug the fbody PCM in and take off, though you will get a SYS light on your dash - you are probably going to get that as well, just an annoyance more than anything.
