Yet another LT-1 ignition question.
Old Oct 18, 2010 | 12:06 PM
hifivinmofo's Avatar
hifivinmofo
Default Yet another LT-1 ignition question.
I developed a miss. I tested and found that cyl. 1 is not firing at all. As well the vent hose from the intake tube to the opti has been cut in half by a pulley. So the question is, should I replace the opti while I am in there? I do have a lift and money isn't a problem, I have actually been thinking about going all MSD pro billet opti, cap/rotor, coil, wires, 6al, wiring harness, and plug change. Opinions welcome.
Old Oct 18, 2010 | 12:22 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Matt,
are you positively sure that the #1 wire is connected? Test the Opti #1 port and if there no spark, I guess you would have to replace it.
I have the MSD Opti, Coil on both of my Vettes and they are great. I use MSD wires on my 95 and Magnecor on my 96. Other members will chime in to give you their comments and details on the 6AL, I dont have it
Due to the fact this is an Opti thread I have to post the-
Old Oct 18, 2010 | 12:33 PM
hifivinmofo
Oh yeah, it is connected. No fire from the opti... Most likely got fubar because of that line was what I am thinking. Used a dealer service program and looks like there was a technical service bulletin on this many years ago about that line and how it WILL EVENTUALLY cause opti failure if/when damaged. Figure eventually is here and might as well go back with nice stuff even if I may be selling it.
Old Oct 20, 2010 | 10:56 AM
hifivinmofo
Yep ordered the ignition kit from Jegs for $906.xx not bad for all that is has with it though. Pro billet distributor, cap/rotor, wires, coil, 6al, and direct fit wiring harness. now I just need a water pump and some plugs... any recommendations on those?
Old Oct 20, 2010 | 11:28 AM
timmy 93's Avatar
timmy 93
Go with a new water pump.Not a reman,or electric with your old housing. Just my 2cents. Tim
Old Oct 20, 2010 | 11:29 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
I bought my WP from O' Reilly Auto Parts for $119.00 (lifetime warranty, no core swap). Sure beats the heck outta' the dealer price of $350 bones.
For LT1 plugs, I like the NGK TR-55 Double Platinums. Set gap at .060 and don't forget the anti-seize compound (aluminum heads). For wires, I went with the NAPA/Belden 7 mm. Super Blue Premium, but Taylor and AC/Delco-Packard ignition wires are great, too.
Old Oct 20, 2010 | 01:30 PM
littlesk8cracker's Avatar
littlesk8cracker
be careful, iv heard of tonnnss of problems with msd optis, coils, wires, etc
Old Oct 20, 2010 | 07:48 PM
Mike96Coupe's Avatar
Mike96Coupe
I've heard a lot of bad things about the MSD opti. The Delco is what everyone has told me to stay with. Just had my pump rebuilt by Water Pump Man in Mich. $70.
Old Oct 20, 2010 | 11:38 PM
92WhiteVetteGuy's Avatar
92WhiteVetteGuy
I got 75K out of my last W/P from Water Pump Man. This time I went with a new GMB pump with a larger bearing and lifetime warranty from Advanced Auto for 91.00 bucks with a 30% discount and free shipping.
Good Luck!
To Yet another LT-1 ignition question.
