is a major pain if you try loosening the fuel lines from under your vette(92 convertible)...what I did was to undo the fuel line at back of the filter and push it through the holder so I didn't have to find the hidden attaching bolt, then remove the wheel and take off the wheel well and there I found the filter, repaced the filter pushed it back through the holder and attached fittings
the reason I replaced the filter was hard starts and rough idle... I almost ordered new injectors found out it was just the filter.
By the looks if it it could be the original one...now it runs smooth and starts right up.
