Troubled
Old Oct 22, 2010 | 04:20 PM
Knuckleduster's Avatar
Knuckleduster
2nd Gear
Default Troubled
I have a '91 with an L98 and I've noticed a bit of shimmy from what feels like the rear end when I accelerate lightly from 55-65 mph. I can mash the gas and it goes away but from 1/4 to 1/2 throttle it feels pretty shaky. When I hit about 70 it goes away and everything is normal so I'm pretty stumped and any help would be great.
Old Oct 22, 2010 | 05:21 PM
ch@0s's Avatar
ch@0s
Have you had your tires balanced. Alignment and balance should be done approximately every 12K.
Old Oct 22, 2010 | 08:24 PM
GKK's Avatar
GKK
Check all the Suspension Bushings for cracks and deterioration. Also, check the wheel hub assemblys for play.
Old Oct 22, 2010 | 09:11 PM
hooked073's Avatar
hooked073
Could be converter not disengauging soon enough causing extra load on engine. Try shifting from od to drive and see if it goes away. Iv seen this a lot. If you are describing what I am thinking.
Old Oct 22, 2010 | 09:17 PM
ch@0s's Avatar
ch@0s
That would be more of a shudder not a shimmy. Just changing the fluid and filter cured this on my DD.
To Troubled
