Can anyone help in finding where the short is? I cannot put a fuse in the CTSY/CLK socket without blowing it immediately. It is suppose to be a 15 amp fuse, but 30s blow also. The courtesy lights, radio, and horn do not work. I have disconnected the radio, removed the horn contact, and removed all the courtesy lights except the two in back of the seats. The fuse still blows immediately when it is installed. Any help would be appreciated.
Don't try the 30A anymore!
If it's not the items that are connected to the circuit then there must be a short to ground on one of the wires.
Try disconnecting the Lighter socket. I think it's in the same circuit. In my experience they go out quite frequently and or people drop things in them.
My old School GPS plugs into the Cig lighter. One day the tip unscrewed and came apart when I was unplugging it.....bits and pieces fell into the Cig lighter and as I was trying to fish them out.....driving 50 mph of course...who pulls over for something like that.....a pop and a fizzle and a whiff of ozone and the radio was dead.....
You can replace the fuse with a 12v lamp which will light if the circuits are shorted, then you start disconnecting devices one at a time on that circuit and see if the light goes out. It may not, indicating that somewhere in the wiring harness, a wire is abraded or pinched and shorted to ground.
NEVER put a larger fuse in place of a burned out fuse!!!!!!!!!!!
I like the idea, but will that work on a circuit that contains light bulbs whose filaments are grounded ?
Yes it will, you determine if there is a short by measuring the voltage on the output wire on the lamp that replaces the fuse. Short circuits are very low resistance and the output wire will measure very low voltage, like less than 0.1 volts while courtesy lights will be over 1 volt.
Clearly you have a short circuit, your circuit instantly blows fuses.
Thanks for all the replies and advice. I have an electronic shop manual for the 84. It is remarkable all the devices on that circuit. The resistance between the 12v wire and ground was 1000 ohms. I think this gives a current of 0.012 amps; not enough to blow 5 amp fuse. After this confusing piece of information I started disconnecting devices on the circuit. Fortunately I had gotten rid of the "breadbox" which made it easy to access what is behind it. After diconnecting several lights, radio, and the horn relay and more blown fuses, I unplugged the connector that feeds the vanity mirror lights and the fuse didn't blow. I have not investigated exactly where the short is but am happy to have things back together.
During my investigations, I noticed a yellow liquid on the floor under the car. Further investigation showed a leak from near the AC/heater fan shroud, probably the heater core has started to leak. Ahh, the joys of an 84; always something to work on.
Thanks again for all the help.
I should have metioned this before but using a circuit breaker will save you money on fuses. Some even have a reset button.
I hope that helps someone in the future.
