Spring rates and fit
Old Oct 27, 2010 | 12:58 PM
RGA121's Avatar
RGA121
2nd Gear
Default Spring rates and fit
I have found a big crack in the front spring on my 95.
The spring is marked FHA and I want a new one with a similar rate. To save some money I want to try to find a used one.
When I have searched here I have found these two lists of spring rates:
http://forums.corvetteforum.com/1553599105-post5.html
http://www.tubas.net/vette/spring-codes.xls
Both lists agree on the rate for the FHA being 93.1
Will the other springs with similar rates (FHC, AA and FSK) fit a 95?
The rates for the FSS differs in the two lists, does anyone know what the correct rate is?
Thanks in advance
Old Oct 27, 2010 | 05:52 PM
StealthLT4's Avatar
StealthLT4
From my research, FSS is 75 N/m (or 73, I forget which), though that probably doesn't make you any more sure than you were before.
EDIT: Now that I actually looked at the links you posted, if you scroll down later in the tread for the first link, someone corrects the FSS rate to what I mentioned above.
Old Oct 27, 2010 | 06:58 PM
rodj's Avatar
rodj
Originally Posted by RGA121
Will the other springs with similar rates fit a 95?
Any '88+ spring will fit
Old Oct 28, 2010 | 11:06 AM
RGA121's Avatar
RGA121
2nd Gear
Thanks for the replies!
Now I know what to look for! Hopefully I'll find a new spring during the winter so I wont miss any driving time next summer
Old Oct 28, 2010 | 04:47 PM
StealthLT4's Avatar
StealthLT4
PM'd you about a possibly available FHA spring
To Spring rates and fit
