I have been having trouble with my overdrive engaging. Sometimes it works fine and other times it will not engage right away, or at all. When it doesn't engage the light doesn't come on and the light always comes on when the overdrive engages. I replyaced the relay and cleaned the connector a couple of years ago. On 10/21/07 a post "Doug Nash 4 + 3 Bhatreakthru" describe how to clean the solenoid that activates the overdrive. The problem he was trying to solve sounds similar to mine so I thought I would give it a try. Has anyone done this and if so can you give me some pointers?
O/d light indicates power is available to the solenoid (light is on output side of relay as shown)
If light not on then either ;
ECM is not operating relay or relay is not outputting power
I recently had the exact same problem. I pulled the plastic cover off of the relay, pushed the relay in with my fingers to see if the OD light came on. I could stand next to the drivers seat and push in the relay and see the dash at the same time. The light came on. So there was no signal to the coil in the relay. So this told me I had problems with the OD switch, switch circuit, ECM or wiring from ECM to relay. I decided to hook the OD switch directly to the relay. The switch grounds the coil to the relay, energizing it, and no more OD problems. Every time I hit the switch, I have overdrive. A good mod. If your light is not coming on, it is not the solenoid.
Also, the ECM needs to see the correct parameters before it will allow OD. Coolant temp is one of them, so if your trying with the engine too cold, you will not get OD.
If the light doesn't come on, cycle the switch back and forth a few times and see if it is just a scratchy connection.
also, check your temps on your temperature gauge, if the temp is too low then the O/D will not come on
This begs the question and I have never seen an explanation as to why the engine has to be a certain temp for the ECM to allow you to switch on the OD? If it is a simple automatic 2 speed transmission, what is the reason for this? And why won't it let you go into OD AFTER romping on it? Now that mine is overriding the ECM, I would like to know.
Like many of the other stock ECM calibrations, most likely for economy/ emissions.
Prevents you loading up the engine until engine is up to operating temp.
Why no first gear OD......hmmmm....other than why you would need it in first gear, maybe the torque multiplication of first gear could damage it in some way. First gear burn outs and switching into OD sounds like fun! lol
Oh my...if this is true, then I am not missing out on much. I would have never have guessed that as a reason.
Yeah, the previous owner of mine, put a 160° thermostat in my car to try to address a overheating issue rather than maintain the radiator/water pump properly.
The I got a hold of the car and went after the over heat issue ASASA (as soon as summer arrived).....once I cleaned the radiator and replaced a failing water pump...new hoses, new coolant etc.....the damn thing started running too cool.
I'd be driving down the freeway and the temps would start dropping.
As soon as they reached 159°, the O/D would drop out.
At 80mph (standard speeds here in SoCal) it is pretty hairy when it just drops out....scares the crap outta me...
so yeah, the computer was reading those low temps and doing what it was supposed to do....take it out of O/D
My overdrive light comes on when it reaches the correct temp but will not go into overdrive. I replaced the relay for the heck of it (same part number as fuel pump relay). and still no OD. What is the next thing to try?????? Please help
If you use Rodj' instructions to determine that the solenoid is still good, the next in the chain is the pressure switch inside the pan.
This is why folks tell you to check the level of fluid.....no fluid....no pressure to that switch.
CentralCoaster begged me to "pull the pan" and see what was going on with my 4x3.....but I resisted out of fear.
Once I got the pan off and after running everyone ragged with questions about the 4x3....and after diagnosing that my issue was the pressure switch.....
I bought a pressure switch and had it ready to install.
Finally...weeks later, I pulled the pan and what did I find?
The beige colored spade connector had fallen off the pressures switch
Read the thread as I put a drain plug on my 4x3 pan while I was there
wow!!! Good post. Thanks for the advice. I will definately pull the pan thursday night and check. I have looked on line looking for a place to buy a new pressure switch and solenoid if I needed them but cant seem to find them anywhere. any place I can look and any idea how much they are ?????
Doubt you will find anything from your local parts shop; definitely not from dealership
