Intermitant failur: Engine cranks, will not run.
Old Oct 27, 2010 | 10:08 PM
joes24's Avatar
joes24
7th Gear
Default Intermitant failur: Engine cranks, will not run.
1992 LT1 series P with 140,000 miles. I installed new fuel pump but problem remains. Should I replace pump relays, or have ECM remanufactured? Any suggestions appreciated. Joe Mayer
Old Oct 27, 2010 | 11:24 PM
Lemme's Avatar
Lemme
St. Jude Donor '10
Do you have spark? What is your fuel pressure before and during cranking?
Old Oct 28, 2010 | 04:21 AM
rodj's Avatar
rodj
will not run.
Will not fire up ( start ) or will not stay running?
Early LT1 , might be looking at a new Opti spark ( distributor ) if original
Old Oct 28, 2010 | 01:40 PM
joes24's Avatar
joes24
7th Gear
When the failure occurs and I try to start, the engine frequently fires once and dies. I have insatalled a complete new ignition system within a year. Battery, coil, distributer, plugs and wiring. When the engine starts normally, it roars into life on first crank. I have to assume plenty of spark is available. A brand new fuel pump last week didn't make any difference so I assume fuel pressujre is not the problem however I don't have the ability to test the pressure. The factory manual indicates intermittant failures are most likely due to electrical connections, or defective relays. Joe
Old Oct 28, 2010 | 01:43 PM
joes24's Avatar
joes24
7th Gear
Thanks for responding. I have replaced the distributor twice; most recently in 2008. It seems to be working fine right now. Joe
Old Oct 30, 2010 | 06:02 AM
Lemme's Avatar
Lemme
St. Jude Donor '10
Testing the fuel pressure and spark by buying a gauge ($50) and a meter ($20) is much cheaper than changing parts hoping it might fix the issue.
Old Dec 31, 2010 | 03:06 PM
richauto's Avatar
richauto
Joe, you never said that you changed the fuel filter. You may have overlooked that.
Old Jan 21, 2011 | 04:43 PM
redvetttes's Avatar
redvetttes
Change the rely's
They burn witch will cause low volts going to the fuel pump
To Intermitant failur: Engine cranks, will not run.
