Dyno Run Was Informative
Old Oct 30, 2010 | 03:01 PM
Brannon's Avatar
Brannon
Default Dyno Run Was Informative
I noticed a slight hesitation in acceleration at 2500 RPM and sought advice to the cause on the forum.
http://forums.corvetteforum.com/c4-t...-2500-rpm.html
After more testing I noticed the lag, or hesitation, occurred at a higher RPM on hard acceleration. I went to True Street Motorsports in McKinney TX to get a few runs on the Dyno to see if I could see the drop in performance. They have a great shop and were very knowledgable, even with my older Vette. I will be taking my business back to them.
There results show a definitive drop in power at 5200 RPM. The technician said he thought the problem could likely be source to something in the ignition system. This supports 96GS#07's thoughts that either the plugs or wires are the source.
So, it looks like a tune-up is in order. Then on to headers, axle back exhaust and a tune.
Old Oct 31, 2010 | 01:16 AM
383vett's Avatar
383vett
Could it be valve float?
Old Oct 31, 2010 | 07:40 AM
Brian Smith's Avatar
Brian Smith
Default Dyno run
What year is your Corvette? You profile show a C6. I thought they had more horsepower than 290.
Old Oct 31, 2010 | 09:49 AM
Brannon's Avatar
Brannon
I have a '96 LT4. I used to have a C6, I just haven't changed my profile yet. I need to do that.
Old Oct 31, 2010 | 10:46 AM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
I have the same problem with my 95, it dies at 5,200 RPMS with 280 RWHP(mustang dyno). 15 years would do that, I'm planning on rebuilding that one too, it has 107,000 miles.
To Dyno Run Was Informative
