My 87 Corvette gets warm inside while driving, why?
I have an 87 that i just restored and started driving and it seems that when i am driving it gets a little warm inside almost like the heater is on low but is not. Is it normal for these cars to get warm inside while driving? If so what can i do to help the situation? Any advice?
Reason: spelling
C4s are quite warm inside, especially earlier C4s like your '87. It's normal. And if you think it's toasty now, just wait 'til the summer time!
There are heat reducing mat sets that install under the carpet which you can get. I don't know how well they work (I don't have one of these sets on my '89) but I imagine they make living with these cars MUCH more bearable. Later C4s had anti-heat matting factory installed.
Ok Thanks guys. I thought there might be something wrong with my car. Sounds like it is normal. I wonder why the C4s are warm like that?
It's not just C4s but Corvettes in general. Apparently with the C6 Z06 you can put stuff in the center console and it gets very hot inside. It's present in all of them, just the newer models do a better job of hiding it.
Is your heater set to the hottest setting even though the heater is off?My car gets hot inside if the temp. is set to the hottest position even if its hot.If set to the coldest setting its fine.Check setting
Like Cuisinart said...you're sitting inches away from the transmission and exhaust; both of which generate tremendous amounts of heat. And if you think its hot in a Corvette, try driving a Viper...even with the A/C on max, those cars are hotter than he11. Not that I condone driving a Viper, I'm merely using it as a comparison tool...
Along with my C4, I have owned a C5Z06 and currently an 08 Z06. The last two are much hotter than the C4.
The car is made of molded INSULATION, once its hot its hard to cool off. Especially hot in FL during the summer with no A/C. I generally put my car up for the summer or only drive it occasionally at night. I also carry a sweat rag with me
let's see, you have this large oval aluminum box just under the passenger compartment.....inside that box is a matrix of screen mesh......that screen mesh is glowing hot while it converts unburned aromatic hydrocarbons into harmless gas......
insulate that oval glowing box from your car and you may have the answer.
Ask anyone that has removed their Cats.....it is much cooler in the passenger compartment and merely opening the windows is sufficient.........like the cars of the 70s.
I have both of the cats removed. But i am new to the corvette driving experience so i was just wondering about the heat. i can take a little heat just to look good in a vette though...lol.
You don't have AC or just don't want to get it fixed? Just wondered!!!
mine does the same, if u have it on 90 even if it's off it will throw some heat, but if u put it down, it doesnt throw the heat anymore... Im glad its not just my Vette!
Well i found out why i was getting so much heat. The cable that connects from temperature controller to the temperature box underneath the passenger dash was rusted and stuck on heat. So i used WD40 and fixed it and now the cable moves freely. Man what a difference now, nowhere near as hot. Much cooler.
