To replace or not to replace: oil pump drive (LT1)
Old Nov 2, 2010 | 09:13 AM
jmgtp's Avatar
jmgtp
Default To replace or not to replace: oil pump drive (LT1)
I'll be replacing the oil pump and main/rod bearings as cheap insurance to keep the bottom end together for the ported heads/cam. Should the oil pump drive be replaced at the same time? Of course the easy answer is yes, but I am on a budget - what is the norm for this kind of work? I plan on limiting the revs to 6000-6300 and I anticipate 350-370 rwhp.
Has anyone had a failure of this part? The current motor has 110k miles.
Old Nov 2, 2010 | 11:33 AM
rklessdriver's Avatar
rklessdriver
Most failures I see on the LTX composite oil pump drive is from people over tightening the retaining bolt and cracking the ear off the housing.
Check it for abnormal amounts of wear on the gear and looseness in the shaft/housing.
As long as it checks out good feel free to re-use it... just don't use a 3/4" drive impact to install it.
If you want/need to buy a new one they are availiable from GM parts counter and only cost about $40.00.
Will
Old Nov 2, 2010 | 01:44 PM
jmgtp's Avatar
jmgtp
Will
Thanks for the reply.
I'm a big fan of my torque wrench and tightening fasteners to spec so hopefully overtorqueing won't be an issue. I guess I'll inspect it upon disassembly. I don't know what I'm looking for as far as wear and tear unless it is obvious so I will likely post pics when the time comes and ask for input. I was expecting a bigger price tag than $40 though.
Old Nov 2, 2010 | 01:53 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
For $40 bones, I'd go ahead and replace it. With my luck, the pump drive would fail as soon as I got everything buttoned down again...
Old Nov 2, 2010 | 02:03 PM
rklessdriver
The oil pump drive is GM P/N 1103868.
GM Parts Direct is showing a cost of $45.69 currently. I'm sure Chris May at Superior Chevy can match it.
Will
Old Nov 2, 2010 | 02:23 PM
Red Rocket's Avatar
Red Rocket
My oil pump drive shaft went out going down the track. Oil pressure went to 0 instantly. Shut it down and towed it home. No other damage.
Going from memory but it seems like the shop said changing cams tends to enhance failures since there is a different wear pattern? Not sure if the GM part is the best way to go with different cam.
To To replace or not to replace: oil pump drive (LT1)
