The Line Loc Installation is about a 2 hour job including the front brake bleeding. Great way to spend a winter afternoon.
We have been perfecting the RSD Line Loc for over a year now. We have been through a few different brands of solenoids, and now our lines vendor is building our lines DOT approved.
Our kit is the best and most complete kit on the market. It comes with everything needed to install except the tools! Our full color photos in our Installation Instructions make the install easy.The key to our Line Loc kit is our stainless steel hoses that allow the Line Loc to hang right under the master cylinder on our patented annodized aluminum mounting bracket.
We now have Heat Protectors for our SS Lines. Just add $15 to your order.
The RSD kit allows the stock brake lines to stay and are connected and used with this kit. If you ever need to remove the RSD line Loc you only have to remove the the Line Loc lines and reconnect the front brake line bac into the master cylinder. The RSD Line Loc sell for $230 shipped on our website here http://www.racespecialtydesigns.com/home.php?cat=56 We accept PayPal and credit cards on the website.
PM or Email me with questions Steve@RaceSpecialtyDesigns
Get it now, get it installed before the snow melts! This project is so easy you only have to jack the car up enough to get the front wheels off to bleed the brakes.
No lift, no getting under the car, no removing seat or anything. Just install and bleed the brakes! Just $239 shipped to you.
Everything in the box to install this Brake and rearend saver!
