A.I.R Pump issues
Old Nov 7, 2010 | 08:11 PM
'84 Maverick's Avatar
'84 Maverick
6th Gear
Default A.I.R Pump issues
First of all, I'm new to this site, and im new to Corvettes in general. I recently purchased a 1984, and the air pump is shot. The pully wobbles and I think the bearings done for because as it idles is screeches like I've heard other vehicles when pulleys seize. So today i removed the air pump and have read that there are delete kits available, my first question is what should i do with it? Use a delete kit or strip the internals of the pump and remount it? Secondly what do i do about all of the secondary components, the hoses and electrical systems attached to the pump. if i use a delete kit will it trigger the check engine light because the pumps obviously no longer functional?... I apologize for the length of the post, but I'm a little stumped and don't want to cause any damage to the car as i just got it and love it! Thanks for any help you can provide!
Old Nov 8, 2010 | 01:30 AM
oldalaskaman's Avatar
oldalaskaman
several venders sell air pump delete kits, depending where you live , a new one might be a good idea, they're not that spendy. Some engines actually run better with them.
Old Nov 8, 2010 | 03:56 AM
'84 Maverick
6th Gear
The kit that I have found ( http://www.mamotorworks.com/corvette?frame=3.842 ) states it's for use on 1985-91, will it still be compatable with my 1984?
Old Nov 8, 2010 | 04:07 AM
samsonb's Avatar
samsonb
I doubt it as the 84 uses a different engine.
I'd say the cheapest and easiest would be to get a rebuilt smog pump from your local auto parts store.
Old Nov 8, 2010 | 04:35 AM
'84 Maverick
6th Gear
I found a remanufactured air pump for $80, they want $150 for the delete kit... If i buy the rebuilt pump can i run it without using the emission control systems and basically use it as an idler pulley?
Old Nov 8, 2010 | 04:52 AM
samsonb's Avatar
samsonb
I believe you can gut the pump and run it like that. But I'd leave the emission stuff in place.
Old Nov 8, 2010 | 08:20 AM
cumbercr's Avatar
cumbercr
There's really no advantage to deleting the AIR system other than cleaning up the engine bay. There won't be any change in performance. Your cheapest solution is to just replace the pump.
Old Nov 8, 2010 | 10:59 AM
oldalaskaman
1984 is a different engine, call the venders tech and make sure of fit.
Old Nov 8, 2010 | 12:02 PM
twotone84vette's Avatar
twotone84vette
I deleted the air pump and the the attached parts and got a shorter belt this summer. No effects on performance.
Old Nov 8, 2010 | 12:19 PM
oldalaskaman
any chance you remember the number of that shorter belt?
Old Nov 9, 2010 | 04:57 PM
jimm1951's Avatar
jimm1951
Navigator
I used an 85 in belt. Worked good.
Old Nov 10, 2010 | 11:54 AM
twotone84vette
oldalaskaman.
I installed reduction pullies and don't know if my size will fit yours. I measured the size I needed with a string. The guys at Napa Auto let me take some sizes larger and smaller to try out. I kept the one I needed and returned the rest.
Someone that removed the pump with the stock pullies told me he used an 85" Mine was around 82 3/8"
Old Nov 10, 2010 | 02:38 PM
qws's Avatar
qws
What a bunch of misinformation in the beginning.
84's do NOT require the use of a delete kit. You simply remove the AIR pump and use a shorter belt
I use the 82 in belt but I also use the reduced size crank pulley. My suggestion would be if all the pulleys are the stock size a 84 or 85 in should fit with no problem
Old Nov 10, 2010 | 02:41 PM
qws's Avatar
qws
They do??
Old Nov 10, 2010 | 03:46 PM
jhammons01's Avatar
jhammons01
At Kragen the pump is ~$50......and 42 minutes to swap
Old Nov 10, 2010 | 07:15 PM
samsonb's Avatar
samsonb
Originally Posted by qws
They do??
OP was asking if the 85-91 smog pump delete would work on an 84. My response was that I didn't think it would since the 84 has a different engine than 85-91.
84 = L83
85-91 = L98
Old Nov 10, 2010 | 11:59 PM
qws's Avatar
qws
84 = L83
85-91 = L98
I'll be!...learn something new everyday.
The 84's are a 350 small block.... what engines do the L98's use?
I would have sworn they use a 350 small block as well
To A.I.R Pump issues
Old Nov 11, 2010 | 12:05 AM
oldalaskaman
its also a 350, just a different configuration,,,,,,I think....I'm sure others know better than me.
Old Nov 11, 2010 | 12:09 AM
qws's Avatar
qws
They are both 350 small blocks...period!
intakes are different, location of accesories are a different. Bottom line they are the same blocks.
I've converted mine from CFI to HSR so what does that make mine?
Old Nov 11, 2010 | 12:17 AM
oldalaskaman
more cool
