Pilot bushing & flywheel questions
Old Nov 9, 2010 | 02:22 PM
glava2876's Avatar
glava2876
Default Pilot bushing & flywheel questions
I am finally pully the transmission to install the T/O bearing, Clutch, PP flywheel & pilot bushing -last night I got it on jack stands and the exhaust off, with no real problems.
I have some questions;
1) I have to get a pilot bushing puller -NAPA has them but I need to be sure that they give me the correct type -what do they look like?
2) What do I use to install the new pilot bushing?
3) I've never pulled a flywheet before, do I need a puller? If so, what type.
Thanks,
Glen
Old Nov 9, 2010 | 02:58 PM
Shark Racer's Avatar
Shark Racer
This was on a BBF, but a SBC should be the same.
1) I used a slide hammer with a pilot bearing extractor. It's basically two fingers that go inside the pilot bearing, and then you tighten a screw and that pushes the fingers outwards where they'll grab onto some notches in the bearing. You then yank on the slide hammer to pull it out. 5 or 6 whacks should to it.
2) I used a socket and very light hammer strokes. Again, I had a bearing, so I used assembly lube on the outside to help it move in easier.
3) Should be a a number of bolts holding it on. Once those are out, it'll fall right off... be prepared to catch it or have someone help you.
Old Nov 9, 2010 | 04:52 PM
glava2876's Avatar
glava2876
Sharkracer, Thanks, Glen
Old Nov 9, 2010 | 08:27 PM
cv67's Avatar
cv67
St. Jude Donor '05
Stuck the bushing in the freezer stuck a touch of mobil 1 around the outside of it once removed, went in super easy. No it wont come out as easy either.
Old Nov 9, 2010 | 08:33 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Thanks,
Glen
1) To get mine out I have a Tap that fits in nice and bottoms on the crank. Turning it slowly it draws the old bushing out very easily.
2)To install the new one I use a large socket and hammer. I do what cruisinartvette said and freeze it, then out a dab of oil on the outside.
3)No puller needed, just loosen the bolts around the flywheel/pressure plate assembly. If you have an alignment tool I would stick it in the clutch before loosening everything, otherwise watch our for the clutch disc to fall when you loosen the pressure plate.
Old Nov 10, 2010 | 12:04 PM
glava2876's Avatar
glava2876
Thanks guys. the exhaust is out, the "C" beam is out& the drive shaft is out -can't work on it tonight, but the tranny comes out Thusday night!
Old Nov 10, 2010 | 01:46 PM
383vett's Avatar
383vett
To get my bushing out, I use a long socket that just fits inside the bushing (5/16, 9/12, or 3/8 or metric, I can"t remember). Fill it full of axle grease, put an extension on the other end and hit it with with a mallet. The bushing will pop out by itself.
Old Nov 10, 2010 | 07:05 PM
rodj's Avatar
rodj
Showing your age
Old skool mechanic trick, no need for fancy extractors
Can use anything that is a snug fit in bushing
Old Nov 10, 2010 | 08:46 PM
383vett's Avatar
383vett
Originally Posted by rodj
Showing your age
Here's one for you. I actually used a AA battery and gtrease once. It works. Obviously, the battery will be beaten. Good in a pinch.
Old Nov 12, 2010 | 09:54 AM
glava2876's Avatar
glava2876
Showing your age
I'm going to try that first. I have the transmission out, so the clutch etc. will all come out tonight.... i'm just working on it a couple hours each night.
See my other post -my 84 has a transmission with a December 87 stamp on the case. No T.V. cable, has the vent tube on top.
To Pilot bushing & flywheel questions
