problems with new corvette
Old Nov 11, 2010 | 12:06 AM
demande's Avatar
demande
4th Gear
Default problems with new corvette
hello well I'm new here i recently bought a corvette a 1992 from this guy by my old school the guy had it parked there all 4 years well i took the initiative asked if he was selling it and i got it for 2000 but it has some problems that i wish u guys could help me out with for starters the hood wont lock if i accelerate over 30 it will pop up and if i go faster it raises both the headlight motors are busted and to make things worst the right one is broken so it wont stay in place also the LCD display seems to blink on and off at randoms times and today it did not turn on at all hmmm also my car even has trouble getting to 100 i don't think thats normal seeing my 2002 Jetta picks it up like nothing and the corvette has way more hp and torque this are just some of the troubles its giving me I've always dreamed of owning a corvette and now that i do i plan on getting it into the best shape possible so i would really appreciate you guys help
Old Nov 11, 2010 | 12:17 AM
ZBRA's Avatar
ZBRA
That jumble of words is rather difficult to read.
Old Nov 11, 2010 | 12:20 AM
demande's Avatar
demande
4th Gear
sorry let me try and make it simple
i got this car 3 weeks ago and is giving me problems it has trouble reaching 100,the hood wont lock so it will open up on me, my headlight motors are busted, the right headlight seems to be broken as it keep falling down unless i tied it down to something (which i did),and my LCD display goes on and off
hope its more understandable now
Old Nov 11, 2010 | 12:48 AM
oldalaskaman's Avatar
oldalaskaman
you spent $2000 for a 92, you got what you paid for. a car with no problems would have cost a bit more. not putting you down , I paid $2000 for an 87 and love it cause its a learning experience, my 2c's
Old Nov 11, 2010 | 01:46 AM
overdrawn's Avatar
overdrawn
''i got this car 3 weeks ago and is giving me problems it has trouble reaching 100''
You paid 2000 and your wondering why you can't get it to 100 mph ??
Old Nov 11, 2010 | 01:49 AM
Jay Axson's Avatar
Jay Axson
A 1992 top speed is near 160. It should be able to break the tires loose in atleast 2 gears.
Lack of power is often lack of compression. It can be a lot of things. When I was a mechanic 25+ years ago and we got a basket case that had sat a long time we would give it a really good tuneup to get in a condition where it should run. Then it still had issues, we knew it wasn't something dumb like a clogged carb jet or something.
Anyway, I would replace the following, wires, plugs, air filter, fuel filter, engine oil, oil filter, and transmision oil.
If it is still weak, I would be suspect of a blown head gasket, weak fuel pump, clogged injectors.
Once you get the plugs out they will tell a tale. They should be tan at the tip. If dark, then you are running rich, if too white you're running lean. While you are changing them it is the perfect time to do a compression test on each cylinder to check if the head gasket is blown.
I hope you have a lot of patience as changing the plugs and sparkplug wires can be a 7-8 hour job. Do them 1 at a time and make sure you route that wire exactly the way the old one came out where it snakes past the AC bracket / tension pulley area. You'll probably have to remove half that stuff just to get to the Optispak. You can also get some from under the car. Buy really good wires as you will have little leverage to get them to click into the opti.
I found that I had a problem where the wires were bad and the plugs had vibrated loose. 3 or 4 of them I could turn by hand! So I had a spark and a compression problem. The approach of getting to where it should run right showed the real problems right off.
Good luck!
Old Nov 11, 2010 | 01:55 AM
Jay Axson's Avatar
Jay Axson
We should be happy someone was willing to take a basket case C4 with the intent to bring it back to some resemblances of its glory. Hell of a lot better than the crusher or being parted out.
So let's help him get there.
Jay
Old Nov 11, 2010 | 04:39 AM
Lemme's Avatar
Lemme
St. Jude Donor '10
The 4 issues you have mentioned are all unrelated so just fix one at a time.
1.Hood - sounds like the release cable is not letting the latches return
2. Headlights - Have to source some replacement actuators
3.Dash - Send it to a service facility
4. Not going over 100 - maybe has clogged fuel filter, needs tuneup. Do a fuel pressure test.
Old Nov 11, 2010 | 06:41 AM
James93LT1's Avatar
James93LT1
Veteran: National Guard
Get yourself the Factory Service Manual.
http://www.helminc.com/helm/Result.a...ected%5Fmedia=
Old Nov 11, 2010 | 08:46 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
OK, lets start slowly - Where do you live?
Get a Factory Service Manual and a good set of hand tools, right now, like TODAY
Hood - look at the cables, if they are in great shape than get some white lithium grease. While someone pulls on the handle grease the area where the latch slides. Pull and release the latch several times. The original grease is probably gone from it sitting so long.
For the head lights look at the head light motor repair sticky above. If you can pull the cover off the motor transmission you can repair them. If not be prepared to buy a set of used motors.
The LCD display could be bad grounds, broken wires, etc. You will need the FSM to troubleshoot.
You got a Corvette for the price I'm looking to pay for a POS Daily Driver, of course its going to have problems. Depending on your budget for repairs this could be a one month to three year project
Welcome to the madness and good luck!
I asked where you live because there may be a member near you or a shop we can reccomend to help you.
PICTURES are required!
Old Nov 11, 2010 | 09:52 AM
demande's Avatar
demande
4th Gear
jaa i live in laredo tx and i was looking at the hood latch last night and apparently the left one (the one that does not lock) is busted i found one online for 21 bucks not counting shipping
as far as the headlight motors i will check that once i get out of work and i will try the greasing as well who knows it might work.
and i think most likely it will be a 3 year project since im about to head out to bootcamp and currently dont have that much money
the LCD display im thinking of taking it to an electrician since ive never been good at electronics i usually end up making things worst in that department
and i will be uploading pictures hopefully by today in the afternoon
Lemme i did the tune up as soon as i got the car i will be doing the oil change again in a week since when i changed it the oil was real dark so i know it probably has build up so i figure re changing it might help
and i will be doing a fuel pressure test if not tomorrow this weekend
jay i suspect my injectors could be part of the problem for the lack of power i already looked around and im gonna take them to get cleaned saturday
as far as changing spark plugs and wires i already changed them i put ac delco spark plugs and accel wires but now i will do a compression test to make sure its not a blown gasket
To problems with new corvette
