1994 Covette transproblem
I put it in drive and it wont move better word engage. It will not engage reverse either.
further before we put in the engine the trans worked fine. this is an automatic.
I check the shift linkage and it is connected. I also observed the flywheel spinning but not the torque converter. Does this sound like the flywheel bolts weren't put in? or is there something else we might have overlooked
If it is the flywheel how do you bolt it up. Also does anyone know the size of the flywheel bolts
