Cam Install Parts Help
I posted a while back about winter mods. I am doing Superram and base, arf tpis heads, tpis long tubes, and a 219 cam.
These are the parts I am getting ready to order. ANy comments are welcome. Is there anthing I missed??
Head Gakets - Fel Pro Q7733PT2
Intake Gaskets - Fel Pro 1204
Oil Pan Gasket Kit - Fel Pro OS34500R
Water Pump Gaskets
Assembly Lube
Scorpion 1.6 Roller Rockers - SCP1003BL
Comp Cams Hyd Roller Lifters - 850-16
Pushrod Length Checker
GM Perf Timing Chain Set - 12371043
Timing Cover with gaskets - SUM-G3200-K
ARP Head Bolt Kit - 134-3601
March Underdive Pullely Set - 4425
Standard Motors Wire Set -
Bosh 02 Sensor
Bosch Platinum IR Fusion Plugs
Summit Water Pump - 312635
Any advice is greatly appreciated.
Thanks,
Mike
Yeah, I'm hoping it wakes my motor up a bit. The timing chain had a lot of slop so im sure that wasnt helping anything. The car was quick but it left a lot to be desired.
Its funny when I drive the vette for a week straight, then switch back to my sierra 4x4. The ABS are locking up and the body rolls all over the place with tires squealing. Forget to match my driving style to the vehicle haha.
Just wondering, how'd you manage to hear what he wrote?
LOL, just pulling you chain; have a Good One.
Jake
Water Pump Gaskets
Assembly Lube
Bosh 02 Sensor
Thanks,
Mike
Don't forget about Lock-Tite for the cam bolts & posi-locks on the roller rockers & thread sealer for the bolts that extend into the water jackets.
Also, the proper tools to remove the balancer hub & the crank gear for the timing set.
http://www.summitracing.com/parts/NAL-12499225/
Head gaskets are wrong unless you are building a 400
Are for 1.250 bore
( you don't state what you are working on! )
Will do on the lifters.
Its a 91 L98. 350 Stock bore. I remember pete K saying thats the head gasket set he has always used on all of his motors. I must have mis understood. Any recommendations for the right on?
The heads are TPIS CNC'd AFR 190cc. These were 187CC heads, 56cc chambers, .625 lift springs, and titainium retainers. They flowed in the low 270's at .550 cfm. We offered them from 1994-about 2001. Theya re a great head for 350 and 383 CI engines.
The cam is a accel or LPE 219/219.
Thanks for all of your help.
Mike
The only thing I can think of is to be sure to make provisions for a tune before you get her fired up initially; that'll make life easier (and safer) on the other end.
What about the the tranny & gearing?
Does anyone else have any imput on the combo of parts listed above? I hope to order all of this later on tonight so I can have everything in when I need it.
Thanks,
Mike
A-1 CARDONE Master Cylinder
BOSCH 12014 Oxygen Sensor
BOSCH 4512 Spark Plug
FEL-PRO 5152 Water Pump Gasket
FEL-PRO OS34500R Oil Pan Gasket
FEL-PRO 13032 Water Pump Gasket
FEL-PRO 70822 Oil Drain Plug Gasket
FOUR SEASONS 26729 A/C System O-Ring & Gasket Kit
GOODYEAR 63163 By-Pass Hose
STANDARD MOTOR PRODUCTS 6892 Spark Plug Wire Set
ARP 134-3601 Head bolt Kit
Assembly Lube
Cloyes Timing Set - CLO-9-3100
Fel Pro 7733PT2 Head Gasket
Fel Pro 1256 Intake Gasket (1204 and 1205 are avail locally)
Under Drive Pulley Set 4425
GMPP Hydraulic Lifters NAL-12499225
Scorpion NSA 7/16th Roller Rockers - SCP1003BL
Summit H2O pump
Intake Manifold bolt kit
Timing Cover
Hopefully I got everything that I cant get locally.
I want to break this in car build up into a few different days.
Next step is to degrease everything, clean up gaskets, clean up parts that I am reusing.
Then I want to install the oil pan gasket, heads, timing chain and cover, and measure push rod length.
Next I want to order pushrods, make sure I have everything for the intake install then install the intake base.
Once that Is done, install all accessories and radiator and condensor.
Lastly is install the SuperRam and button everything up.
This car will not be driven until March so I have plenty of time, but I am fighting the weather.
I want to pull my dash apart and replace the heater core, and try to get rid of any squeaks and rattles.
In the summer, I plan on doing weather Stripping and fixing my door panels.
I have already replaced the brake booster with a metal one, plan on a brake master cylinder, replaced the clutch master and slave.
The clutch is new, and a used DMF was installed in July. It replaced a Findaza SMF.
Lastly is a nice set of ZR1 rims and new tires. My current ones passed inspection, but will not pass again in 2012.
This board is great but it really teaches you how to spend money.
Thanks,
Mike
Once you have the correct priming tool, you then attach the priming tool to a 1/2" drive drill (3/8" drive drills usually over-heat), remove the distributor and insert the priming tool into the intake manifold hole when the distributor would normally be inserted.
Index the priming tool with the oil pump drive rod and start the drill. This will cause the oil pump to turn and cause oil to flow thorough the entire engine. You'll need to manually turn the engine over many times (1/4 turn at a time) with a ratchet/socket to cause oil to reach all the rocker arms. You should continue priming until oil is seen flowing from all 16 rocker arms.
I prime mine until there is no sign of air coming from any of the rockers along with the oil. At first oil and air will exit the rocker arm at the same time but I continue priming until it's only oil, with NO air. I prefer to purge all the air from the system.
I always install a oil pressure gauge on the rear of the block so I can monitor the pressure as I operate the drill. That's optional but a good idea.
Hope this helps.
Jake
It took 20-30 seconds to prime the engine. The pressure came up to 40psi by using the starter. After about 1 minute, I let the starter rest. Then, I hit it for another minute.
I confirmed oil was up at the rockers (though not much) before installing the rocker covers. This lets you know your oil pump is working.
Had I not seen 40psi on the gauge, I would have gone the priming tool route. OTOH, spinning a motor with the starter for 1 minute probably doesn't make the starter very happy. That's why I didn't do it for too long (and repeated the prime after a rest).
Jake
