rocker panel pic request
Old Nov 15, 2010 | 03:15 PM
jon0108's Avatar
jon0108
Default rocker panel pic request
I'm in the process of having my rocker panels repainted. They were done once before by the previous owner and he had the entire piece including the lower lip,( where the jacking points are), painted also. After time it started to chip. I believe that this lower lip area was never painted from the factory. It was left a flat black color. If someone could snap a couple of pics showing exactly where the factory paint is supposed to be, it would be much appreciated.
Old Nov 15, 2010 | 03:47 PM
96GS#007's Avatar
96GS#007
On my '90 & '96, the entire panel is painted including the lower lip.
Old Nov 15, 2010 | 03:50 PM
jon0108's Avatar
jon0108
Thanks. I'm actually searching pics on the forum and it seems like early C4's had the lip in black and later C4's had everything painted. Not sure though. I'll keep searching
Old Nov 15, 2010 | 04:00 PM
Sky Vette's Avatar
Sky Vette
1989 - the very bottom edge where the lettering is (^ JACKING LOCATION ^) painted black, not body color.
Old Nov 15, 2010 | 04:01 PM
eatmydst1234's Avatar
eatmydst1234
i can take a pic for you if you want, but the bottom half of my car is black..
Old Nov 15, 2010 | 04:04 PM
jon0108's Avatar
jon0108
Bingo. Thats exactly the area Im talking about. My car is yellow and that area is all chipped up exposing black. I dont think its paint though, it looks like its the actual lip of the rocker panel that was manufactured with black plastic.
Old Nov 15, 2010 | 04:53 PM
jon0108's Avatar
jon0108
Still would like to see pics if anyones got em
Old Nov 15, 2010 | 05:33 PM
pmihaltian's Avatar
pmihaltian
Slingshot
The rocker panels on early C4s were painted the same color as the body with the exception of the 1" flat strip on the very bottom which was painted dull black (same as under hood black), not flat black, not semi-gloss black, but a dull underhood black. Also, the 5 7mm bolts that were used to attach the panels on the bottom were anadized black (not painted). Here are a couple of photos. If these don't do it for you, I can take some close-ups tomorrow and post them.
P.
Old Nov 15, 2010 | 05:36 PM
jon0108's Avatar
jon0108
Thanks Peter. I would really appreciate it if you could take some close ups of the area in question.
Old Nov 15, 2010 | 05:38 PM
pmihaltian's Avatar
pmihaltian
Slingshot
Okay, I'll take a couple close-ups and post them for you tomorrow.
Old Nov 15, 2010 | 05:39 PM
jon0108's Avatar
jon0108
Old Nov 15, 2010 | 06:41 PM
pmihaltian's Avatar
pmihaltian
Slingshot
Okay. here you go.
While the lower edge appears to be black plastic or ABS, it is not. It is painted. If you ever remove your rocker panels you will see on the reverse side that the plastic is actually a butternut honey color. The rocker panel is painted body color and the 1" flat strip is painted dull black. You can always tell an early C4 that has been repainted when the lower rocker panel flat strip is painted body color.
FWIW,
Old Nov 15, 2010 | 06:48 PM
jon0108's Avatar
jon0108
Thanks for the pics. I see that the lip area is black. What about the underside area,the area where the 5 7mm bolts attach the panels on the bottom? Is that area black or body color? I know, I know, I'm starting to sound like a pain in the ***
Old Nov 15, 2010 | 08:02 PM
Coupe89's Avatar
Coupe89
St. Jude Donor '05-'06
Here you go. I have a few rocker panels floating around the garage.
Old Nov 16, 2010 | 01:45 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Only the flat strip is painted black. The area where the 7mm bolts attach is body color. You can mask the painted area leaving only the flat strip exposed. Use Dupli-color or Eastwood under hood black to paint the black strip. You can paint the 7mm bolts flat black which will pass all but the most discriminating NCRS judge’s inspection.
Old Nov 16, 2010 | 01:49 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Todd:
This rocker panel is not the early version. The 84-87 MY panels only had the little triangles and no Jacking Location lettering.
Old Nov 16, 2010 | 01:50 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Nice garage floor !
To rocker panel pic request
Old Nov 16, 2010 | 07:52 AM
kenmohr's Avatar
kenmohr
This is from an 89 as it came from the factory. Hope it helps.
This is not paint but the bare material itself. The nicks are the same color as the un-nicked
Old Nov 16, 2010 | 08:43 AM
jon0108's Avatar
jon0108
Todd:
Old Nov 16, 2010 | 08:45 AM
jon0108's Avatar
jon0108
Thanks everyone for your replies. I actually started scraping the yellow paint off the lip area to expose the flat black. But its time to send them out to have done right. Once again thanks for the replies and the pics
