Softer springs?
.Another plus(having softer spring rates) is when more power gets added to the engine(LE3),the softer springs with offer more weight transfer.The roads are not that great here & I am sick of my car crashing over bumps/potholes.Anyone here have "soft" springs put on their FX3 equipped vettes?Anyone else done this on their vettes-non FX3?Will sway bars help soften the ride?What you guys think/opinions?
92 / 93 FX3 had same springs as FE1 which was 2nd softest fitted to any C4
92-96 FX3 also came with same sway bars as base FE1; smallest fitted in those years
I ride around in my 93 with my FX3 in sport most of the time. Why, I hate the little bit of floaty feeling I get in touring. Sport feels like it settles the car down and has less body movement. I live in a winter state (PA) and only on potholes and big cracks does any suspension crash come through. Then again our roads around here are pretty decent so, and I am used to a tough riding car.
96 used the softest spring rates.
popular misconception is that a stiff suspension will corner better than a softer one, but genuine race car testing has proven, many times over, that the softest springs that can be used without 'bottoming' the chassis on the the road or the suspension stops, will allow fastest cornering...'limiting' factor for most apps (vettes esp) is 'ride height' (aka 'ground clearance'), i.e., low ride height requires stiff springs to 'keep it off the sheets' (low ride IS desirable to help achieve low 'center of gravity' with attendant reduction of lateral weight transfer/tire loading, don't 'jack' your vette up if fast turns are on your menu).
anti-roll bars (aka 'sway bars', arb's) were invented to allow softer ride quality when driving on straight roads while maintaining acceptable 'lean' during lateral acceleration (cornering)...arb's always 'add' some spring rate overall, mostly a relatively small contribution (few 'street' drivers will even notice if the arb's are attached/removed )...common 'racing' practice is to change springs as a 'coarse' adjustment to cornering, then 'fine tune' with arb's front/rear.
Wow I didn't know that my car is equiped with the softest springs.I do enjoy driving my car hard but would like it to ride smoother.Being a flimsy chassis plus bad roads here in Minneapolis=crashing over bumps.I love the adjustability of the FX3 & do notice its alittle more floaty in touring setting but believe the car also handles better in that setting.When in perf. setting it firms up noticeably with a very sporty/firm ride.I normally drive in sport as well as its a nice trade-off in ride & ride firmness.Anyone here installed softer shocks with their FX3?How about without the FX3?I took video of my vette right before it was put away in storage.I'm gonna try to upload that for sure in the next couple days.Its a beauty
Anyways with the softer spring rates it will help with weight transfer with the LE3 package.Anyone with the LE packages or other performance upgrades now not able to put the power down(without slicks of course)?I want usable power to put to the ground with street tires.Don't understand those 1000hp mustangs.All that power is basically useless without slicks.On Youtube theres a 2003 mustang cobra with 600rwhp that loses to a stock Mercedes E55 AMG
My traction control is always cutting in,in the rain.Don't want a car that acts like that in the dry with all that unuseable power.I know I can call vendors or suppliers & ask but wanted your guys opinion/experience
And softer is not better, it is purely situational. If you are skitting over bumps while cornering it is irrelevant if you have slightly softer shocks or spings. Your car is not going to get good grip. If softer is better, your Grandmother's 1982 lincoln would handle better than your vette.
