4+3 installation help needed
Old Nov 18, 2010 | 08:23 AM
glava2876's Avatar
glava2876
Default 4+3 installation help needed
My snails pace clutch job is at a standstill. I have the Clutch, PP and bell installed. I have the trans in through the T/O bearing and clutch and the bolt holes lines up, but I can't get it all the way in, have about a 1/2" gap and can't get enough push to slide into the new pilot bushing.
I'm working with jack stands -the large 6 ton versions, so I have about an 18" workspace -not too bad.
Is there any trick to getting the trans all the way in? I can hand tighten all 4 bolts, so everything is lined up -HELP!
Old Nov 18, 2010 | 08:52 AM
c4cruiser's Avatar
c4cruiser
Try having a helper push the clutch pedal down (slave cylinder hooked up to the bellhousing??) while you push the trans forward. Could be just a small misalignment of the clutch disc that is not allowing the input shaft to slide into the bushing.
Old Nov 18, 2010 | 05:49 PM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
I find this always works when I have this issue.
Old Nov 19, 2010 | 10:25 AM
glava2876's Avatar
glava2876
Thanks, I have been traveling for work and have not been able to try this... but tonight I'm going to try this method!
Should I just leave the 4 bolts hand tight or should I loosen them a little?
Thanks again!
Old Nov 19, 2010 | 11:42 AM
redrose's Avatar
redrose
loosen the bolts a half turn...may have the trans input shaft shaft 'clamped' against the pilot bearing (bushing) with the bolts 'hand tite'
normal to have the trans input argue with pb until helper relaxes the press plate by depressing clutch pedal, esp if using a plastic 'pre-alignment' tool, even my 'precision' steel alignment tool ain't perfect... ('fork puller' can be made ez from a small turnbuckle if you do this job often)
To 4+3 installation help needed
