l98 boost?
Old Nov 24, 2010 | 09:48 AM
Joe Tagliarini's Avatar
Joe Tagliarini
Default l98 boost?
Like 2 weeks ago i bought a custom rear moutn turbo to put in my 85 corvette wit 6 sp manual ( richmond 6sp manual) and i was wonder what is the max boost i can run save wit out blow my engine?
and i bought a meth kit too, it helps??
the custom rear mount turbo is 80mm turbo wit ceramic ball belrings and 60 wastegate.
Old Nov 24, 2010 | 10:14 AM
bjankuski's Avatar
bjankuski
I would guess you could run at least 10lbs with the water meth kit. Push it as far as you can until you see detonation and then back off a little.
Old Nov 24, 2010 | 10:39 AM
tequilaboy's Avatar
tequilaboy
Without any fuel or spark changes, 4 psi is probably enough to blow it above 5,000 rpm.
How are you going to fuel it? How are you going to control ignition timing?
Properly fueled and controlled, it may live for awhile at 10 psi depending upon the actual air charge temperature, fuel quality, rpm and state of tune. No simple answer.
Old Nov 24, 2010 | 12:12 PM
btr85vette's Avatar
btr85vette
Just curious, what kit did you buy? STS?
Old Nov 24, 2010 | 12:44 PM
bjankuski's Avatar
bjankuski
I was assuming correct tuning, all bets are off if you cannot correct the tune.
Old Nov 24, 2010 | 04:29 PM
Joe Tagliarini
well is custom rear mount so idk if is from sts,
im bought a msd 6btm and im getting fmu vortech fuel regulator, so far i think im good,
Old Nov 24, 2010 | 06:47 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Ahhhh, this is a forum.? Not a cell phone Bro.
Old Nov 25, 2010 | 07:00 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
Old Nov 26, 2010 | 03:28 PM
Joe Tagliarini
Okayy??
Old Nov 26, 2010 | 06:38 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Okayy??
Don't pay any attention to him, Joe. You're post was completely legible. You only missed a letter or two. I understood it completely. RifleCoach is nit-picking on this one.
Old Nov 26, 2010 | 10:26 PM
90Indy's Avatar
90Indy
I guess I keep being a bubble buster on boosting a stock L98. With my experience with boosting a stock L98, I would highly advise against it. There are just too many variables with forced induction that someone new to FI does not take into account. As I have stated on previous threads, spend your time and effort on heads/cam/exhaust (if you want to keep the stock bottom end).
You will not be happy with just adding boost for the long haul. I tried it on a stock L98 with 50,000 miles and I was very disappointed until I built an engine designed to run boost. FI is fickle and very destructive when not properly controlled (tune) and when the components (hyper pistons) are not designed for it.
I love my car now (forged 383, 11 psi boost, blast to drive) but there was a time when I told my wife it was destined to be a yellow flower planter in the front yard. FI takes a little dedication, $$$ and allot of attention to detail. Do not take short cuts or you will wind up with more problems ($$) than you had thought possible.
Good luck. Think about it before you make the leap.
90Indy
Old Nov 26, 2010 | 11:15 PM
1985 Corvette's Avatar
1985 Corvette
90Indy
He is correct, research concerning FI is just as valuable as the dollars going into the build. Everyone's experience is different but it won't be a good feeling when something internal lets go mid rpm band. I personally would never consider FI unless I had done the research to construct a sbc designed to support boost applications.
Old Nov 27, 2010 | 09:32 AM
Joe Tagliarini
Thx guys.
To l98 boost?
