Injector and Compression questions
I have a 1989 Corvette. I am going to do a compression test on the engine. (Need to make sure the engine is still good) Does anyone know how much PSI a good 1989 Corvette should have in each cylinder?
Also, I am going to replace all the injectors in the car. My local Kragen has BWD, ACCEL and Delphi injectors.... Anyone have any sugjestions on brands. I can get sets of 8 ACCEL injectors pretty cheap. If someone could tell me correct spray pounds that would be awesome. They have 21lbs 23lbs 24lbs 26lbs 30lbs. I tried looking through the injector thread but I didn't see pound specifics.
Thanks!
