Oil Leak?
Old Nov 27, 2010 | 01:57 AM
armybyrd's Avatar
armybyrd
Default Oil Leak?
I had the Vette on a lift yesterday and noticed some oil on my drivers side header bolts and spark plugs. Im thinking its the valve cover gaskets. Would a bad headgasket leak oil out where it meets the block? No antifreeze leaking btw
Old Nov 27, 2010 | 02:11 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
When you get the oil pan gasket I suggested in your other post, get the valve cover gaskets that are made the same way. They both have steel crush sleeves in them to prevent over tightening.
Old Nov 27, 2010 | 02:17 AM
armybyrd's Avatar
armybyrd
I already have the blue rubber felpro valve cover gaskets from a few yrs back that I changed. Im hoping its just the valve cover gasket
Old Nov 27, 2010 | 02:18 AM
Midnight 85
Sure sounds like it to me.
Old Nov 27, 2010 | 02:25 AM
armybyrd's Avatar
armybyrd
Alright maybe Ill be ok by pulling the valve cover and taking a look at the gasket. With these blue fel pros no added rtv is needed right?
Old Nov 27, 2010 | 02:36 AM
korvette4u's Avatar
korvette4u
no added rtv needed, sounds like thier could be misaligned,, which is very possible if they were not glue into place on the cover side.. but first tighten the bolts first see if that fixes the problem
Old Nov 27, 2010 | 07:23 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Before you change out your valve cover gaskets, make sure they are properly torqued down. They are only torqued at about 8 ft. lbs. so they can easily and often become loose. This may be your problem and, if so, its an easy fix. Check it out.
To Oil Leak?
