I am putting the interior back into my 1986 coupe. I have the middle hi-brake light wires connected correctly and the halo lights are correct, I don't remember what plugs into the this white clip with the black and red wires. What would plug in at this area?
It has been apart for more than a year and my memory is only good for about a month these days.
Any help would be appreciated.
Don't recall the wire colors,but they might be for the interior temp sensor used by electronic climate control. It's mounted into the halo panel and has a tiny grille.
Electronic climate control must have been an option??
I do not have a tiny grill of any type in that area of the halo panels and the controls on the dash are the slider bar with ***** to turn. I suppose I should hook up the battery and test for power at the wires.
