Knock sensor question
Old Apr 5, 2002 | 09:44 PM
Lone Ranger's Avatar
Lone Ranger
Default Knock sensor question
Where is it on a '95 LT1?
And what is the sensor that is plugged into block right by the starter, with heat shield around it, and it has a twin (identically shielded sensor) on the otherside of the block in the same place. Both these can only be gotten to from underneath the car.
Old Apr 5, 2002 | 09:49 PM
STL94LT1's Avatar
STL94LT1
Default Re: Knock sensor question (95_C4_convertible)
Those are your knock sensors.
Old Apr 5, 2002 | 09:53 PM
Lone Ranger
Default Re: Knock sensor question (STL94LT1)
Well, then....... AH HA!!! :yesnod: The driver side one wasn't plugged in tight (wire harness, that is)! Not sure what if any effect that would have, but now it's plugged snug :yesnod:
[Modified by 95_C4_convertible, 7:54 PM 4/5/2002]
To Knock sensor question
