Motor Cleaning ??
Old Nov 30, 2010 | 07:38 PM
derekguzz's Avatar
derekguzz
Default Motor Cleaning ??
Weird question but I just recently pulled my motor and I have heavy thick gunky oil EVERYWHERE...
How should I start to clean this block ?? I am going to heavy degrease the engine bay and power wash ( cover connecters ) but how do I clean all my block, intake ect...
Old Dec 1, 2010 | 10:23 AM
sailorsteve's Avatar
sailorsteve
I still use the old standby, Gunk brand degreaser and a stiff bristle brush. Whatever method you use will make a gloppy mess, if you do it over a piece of plastic sheeting, newspapers, or a piece of cardboard the cleanup will be easier.
Old Dec 1, 2010 | 10:35 AM
engle1147's Avatar
engle1147
Pick up a cheap ($2) shower curtain liner at Walmart.....your choice of clear or white.
Old Dec 1, 2010 | 10:58 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
I got in the engine compartment with a bottle of Purple Power, can of JUNK, several rags, soft wire brush, and LOTS of patience.
I actually returned a couple more times before I was satisfied. It can't hurt to have a can of low-gloss black paint handy. Masking tape too.
(I used some hi-heat low-gloss engine paint I had left over to get a decent color match.)
Old Dec 1, 2010 | 11:18 AM
DonF's Avatar
DonF
Yup, you might have to do this a couple of times, but it will be wprth it
Old Dec 1, 2010 | 01:13 PM
derekguzz's Avatar
derekguzz
there is just all these little crevices that I cant get to with a brush. I have the motor out so Its easy to get to every part but still. I power washed the engine bay a couple mins ago and that came out good. I just wish I could blast the block as well..
Old Dec 1, 2010 | 01:22 PM
sailorsteve
As I understand it, your engine is still assembled, heads, internals, etc. It is important to keep water out of the cylinders, rotating parts, any electrical bits that are still installed, lifter gallery, oil pan, etc. If you are absolutely sure you can do this, go at it. If I were doing the cleaning, I would not take the chance, maybe someone else has a different view.
Old Dec 1, 2010 | 01:40 PM
derekguzz's Avatar
derekguzz
No I agree I am not putting water anywhere near the block. I have the valve covers off and intake ect. I just dont know how all you guys get yours soo clean. I guess once I remove all the internals I can then send the block ect to a place that will clean it brand new
Old Dec 1, 2010 | 02:28 PM
VetteMed's Avatar
VetteMed
Brake cleaner works great too - you'll burn through a lot of it, but it is handy for busting loose some tough grease and grime... Leaves no residue behind either, so rinsing is not required.
Old Dec 1, 2010 | 03:21 PM
JAKE's Avatar
JAKE
HOT WATER (garden hose connected to clothes washer hot water line) and dish washing liquid if I do it at home. I go over the engine many, many times.
When I have a helping hand to lift it, I take the empty block to a local car wash and use the 'cleaner/degreaser' setting and the high pressure wand. I make sure to have plenty of quarters.
If at home I then blow dry the block being careful to blow out ALL the holes. If at a car wash I dry the machined surfaces with towels, then oil them.
Jake
Old Dec 1, 2010 | 05:25 PM
sailorsteve
If you are tearing down the engine, as in, completely disassembling, then you can use your pressure washer on the parts, blow it out afterwards with air, and, as Jake said, don't leave any surfaces wet, oil them so they don't rust.
Old Dec 1, 2010 | 05:28 PM
96GS#007's Avatar
96GS#007
If you're tearing it down and taking it to a machine shop to be checked, they'll hot tank it. No need to worry about cleaning it at home
If you're not tearing it down, then brake cleaner or careful application of Simple Green or Gunk Engine Degreaser. Make sure you don't spray any of the above on the various rotating parts or bearing areas.
Old Dec 1, 2010 | 08:29 PM
JAKE's Avatar
JAKE
Problem is that some shops that are really meticulous about the cleanliness of their shop/machines, etc., won't accept a greasy/oily block. Reher & Morrision won't.
Many years ago R&M refused to accept the very first bare block I took to them. I had to take it to a local car wash, clean it, then return it to them.
The block wasn't very greasy/oily either. I mean it only a surface coating of oil. That engine had only recently been re-built (NO, not by me) and only lasted less than one hundred miles before the mains went south. That was compliments of ALFRED; one of those guys who doesn't give a "hoot" about paying Attention To Detail.
A few weeks ago I dropped off a LT1 block at R&M but, having learned my lesson, I beat them to the punch. I washed the block before even heading in their direction to drop it off.
BTW, shop cleanliness is one of those things that tells me about the shop, how it's run and the quality of their work. How the technicians (the guys who do the actual work) dress is something else I pay attention to.
Just some more on how I do stuff, LOL
Jake
Old Dec 1, 2010 | 10:40 PM
biggrizzly's Avatar
biggrizzly
2015 C5 of Year Finalist
On your other post about the timing cover I showed you before and after photos. I did the same things these guys are saying. Get a floor covering or tarp, lots of gunk and purple power, brushes and rags. I also used a hand pump garden sprayer with water to help rinse the mess without using a full force hose inside my garage and that worked nicely to rinse small areas as I cleaned
Old Dec 1, 2010 | 11:05 PM
derekguzz's Avatar
derekguzz
thanks for the advice !!
Old Dec 2, 2010 | 08:44 AM
sailorsteve
Keep us posted on your project!
Old Dec 2, 2010 | 10:06 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Simple Green and a whole heap of shop towels for me.
Harbor Freight Tools also sells a professional quality steamer/degreaser that's dope, too.
To Motor Cleaning ??
Old Dec 2, 2010 | 10:29 AM
larry93lt1's Avatar
larry93lt1
From: Gaithersburg MD A member since 2007 but then the computer crashed and then the car crash loss of memory X 2
Or you can do it in your neighbors driveway.
Old Dec 2, 2010 | 10:33 AM
larry93lt1's Avatar
larry93lt1
That hand pump garden sprayer works well with a little bit of 'Dawn' dish washing detergent. Hot water also helps.
Old Dec 2, 2010 | 11:08 AM
derekguzz's Avatar
derekguzz
well I am taking my whole block to a very good performance shop here in NC that is going to rebuild the whole motor top to bottom and clean it all up as well for $1,900. I told him I would pay that much just to have it cleaned. I went to lowes and got some wire brushes for the drill and I am going to town here in a minute on some brackets and I will take before and after pics !
