Custom air pump delete bracket
Old Dec 1, 2010 | 08:47 AM
1986-z51's Avatar
1986-z51
Default Custom air pump delete bracket
Looking for some plans to make a air pump delete bracket. Its looks easy to make. I have a fab shop here at work. 1986-L98
Old Dec 1, 2010 | 09:08 AM
Aardwolf's Avatar
Aardwolf
I haven't been a fan of those. How about making a small bracket to move the alternator so a extra pulley isn't needed?
Old Dec 1, 2010 | 09:12 AM
ch@0s's Avatar
ch@0s
I have mine off. I can take pictures and measurements for you. Maybe even trace it out on a cardboard and mail it to you.
Here is what it looks like.
Old Dec 1, 2010 | 11:56 AM
USAsOnlyWay's Avatar
USAsOnlyWay
Shoot if you end up doing that Ch@os, count me in for one. The one thing I haven't figured out yet is what to do with the pulley, did you make that spacer or is it just round stock. I'm thinking the pulley needs a shoulder to ride on but I'm not sure.
Old Dec 1, 2010 | 12:16 PM
ch@0s's Avatar
ch@0s
It's a Korvette4u I bought it from a forum menber. I think they went out of business.
here is one for sale
http://calgary.kijiji.ca/c-cars-vehi...AdIdZ243967363
Old Dec 1, 2010 | 04:22 PM
MyFirst90coupe's Avatar
MyFirst90coupe
That sounds like a good idea. Wonder if anyone has done that.
Old Dec 1, 2010 | 05:14 PM
Aardwolf's Avatar
Aardwolf
Member redrose was selling a bracket he made awhile back. I saved the pictures:
I just used a new top alternator brace:
It's less cost, less complexity, less weight, and less things that can break. Plus less parts to R&R.
Old Dec 1, 2010 | 05:52 PM
klkordzi's Avatar
klkordzi
I have an 85 and used the cast steel bracket for the air pump as the main piece for the bracket I made up. When the bracket was turned around it matched up with two mounting pints on the head. I got a pulley from Autozone and fabbed up a couple supports from flat stock.
Old Dec 1, 2010 | 05:53 PM
MyFirst90coupe
That is very nice!
Old Dec 1, 2010 | 06:41 PM
rodj's Avatar
rodj
with the TPI setup ,you can't move the Alt inboard enough to prevent the return side of the belt from Alt rubbing on the belt over the PS pulley
Works if you delete the A/c and run a shorter belt from Alt to WP
http://forums.corvetteforum.com/1566807620-post48.html
Old Dec 1, 2010 | 10:10 PM
redrose's Avatar
redrose
Default btdt
local yokel that made these is not doing anymore.
Old Dec 2, 2010 | 12:47 AM
korvette4u's Avatar
korvette4u
hey ,, i alive and well...got garage sale happen pm me
Old Dec 2, 2010 | 12:56 AM
korvette4u's Avatar
korvette4u
nice hows it working? the reason i havent been around moved up to C5 and new C6
Old Dec 2, 2010 | 09:26 AM
ch@0s's Avatar
ch@0s
I love it.. fits great and cleaned up the Engine bay.
Do you still make them?
Old Dec 2, 2010 | 06:16 PM
korvette4u's Avatar
korvette4u
private pm
Old Dec 2, 2010 | 08:48 PM
ls1transam84's Avatar
ls1transam84
Here is what I am running.
Old Dec 2, 2010 | 09:00 PM
ch@0s's Avatar
ch@0s
Did you make that ?.. looks good.. I think I'm going to polish mine someday.
To Custom air pump delete bracket
Old Dec 2, 2010 | 09:43 PM
ls1transam84
No I didn't make it, but it would not take much. It was on the car when I got it, if I ever have it off I will get some dimensions.
Old Dec 2, 2010 | 09:47 PM
ch@0s's Avatar
ch@0s
The one I have is more complicated. It fits a little better IMO..
Yours would be easier to replicate and looks great.
Old Dec 3, 2010 | 09:15 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I made this one for my 86, to use the stock belt. If I make another one, it's going to be shorter and use whatever belt fits.
Here is some info, although the template size may vary due to different printers, the measurements are good.
http://members.shaw.ca/dankai/Air%20...Delete%20Info/
