poping when I down shift
Old Apr 6, 2002 | 08:15 AM
CJ454's Avatar
CJ454
Cruise-In II Veteran
Default poping when I down shift
OK here is the deal.
My car pops out the exhaust and gurgles when I down shift some times. :sad: Not al the time. It seems to be when it is cold or when I am a bit aggressive. Acceleration and up shifting are fine. The car only has 41K on it. So I am not sure why it would be doing this.
Sticky valve? Why?
Also my steering rack makes a noise. I was told it could be the rack its self. Do they make a rebuild kit for the rack? I do not want to replace the rack. I was quoted $500 just for the parts.
Thanx
CJ :flag :chevy
ps I still have more of those borders if anyone is interested. A few people backed out.
Old Apr 6, 2002 | 09:01 AM
GlockLT4's Avatar
GlockLT4
Default Re: poping when I down shift (CJ454)
Dunno about the steering rack, but the "gurgle" is a sound that everyone goes for :yesnod: :yesnod: Be glad you've got it :yesnod:
Old Apr 6, 2002 | 10:36 AM
Torre's Avatar
Torre
The popping noise can be anything from wrong timing, wrong fuel mixture to leaky valve. I'd guess one of the first two. Also, if you do not have enough back pressure it may pop. There should be some restriction in the exhaust.
Old Apr 6, 2002 | 11:24 AM
bogus's Avatar
bogus
if the popping is engine related, the early batch fire LT1s are noted for a bit of back talk.
Old Apr 6, 2002 | 04:50 PM
86VetteBill's Avatar
86VetteBill
I'm not sure if this will help or not, but I also have an '83 V65 Magna that pops during deceleration. The consensus on the V4 board is one of 2 things:
1) the pilot screws need to be adjusted a little richer because there's not enough 'fuel to burn completely' being delivered from the carbs
Since you don't have a carb with pilot screws, can your TPS be out of adjustment? (.54 idle and 4.65 WOT) Or do you have an dirty IAC?
2) there's a leak in your exhaust system.
I'm not sure why this would cause popping, but maybe it'll help you out.
Hope this helps.
Old Apr 6, 2002 | 08:42 PM
CJ454's Avatar
CJ454
Thanx for all the ideas. The exhaust is fine. Factory exhaust on the car.
I am not sure how one would adjust the fuel mixture on the car. Any thought on how to adjust/check this?
CJ
:flag :chevy
Old Apr 6, 2002 | 08:53 PM
GlockLT4's Avatar
GlockLT4
Ahh.. stock exhaust .. that's another story. As said above you shouldn't have any weird noises coming from it. If you had aftermarket exhaust and were getting a few small pops on deceleration and gurgling as well, I'd say it isn't a problem.
Old Apr 6, 2002 | 11:04 PM
85WHITEZ51's Avatar
85WHITEZ51
Default Re: poping when I down shift (Glock'94)
Rack and pinion will cost you $250 max. I spent $135 for my rebuilt one.
Old Apr 6, 2002 | 11:52 PM
VMAX451's Avatar
VMAX451
It's normal, mine did it with the stock exhaust too. Sounds cool to me, don't know why, but it does. I think the ecm cuts off the fuel on overrun, which results in a lean crackle.
Old Apr 7, 2002 | 12:04 AM
Zix's Avatar
Zix
I don't think you need to worry, mine did it with the stock exhaust as well...and it does it with the Corsa system too, just a little louder now! And EVERY motorcycle I have ever owned has done it as well and they were all solid as a rock, just like the Vette. Enjoy it, it's a nice sound!
Old Apr 7, 2002 | 09:16 AM
CJ454's Avatar
CJ454
Thnax for the help on the exhaust issue. I guess I will wait it out and see what happens.
To the guy who found a reblt rack where did you get it? Where can I get a new one for that price?
CJ:flag :chevy
Old Apr 7, 2002 | 11:01 AM
Torre's Avatar
Torre
86Vette Bill's comments confirm my post as well.
And No, it does not sound "cool". It sounds unhealty and a mechanic would shurly giggle if he saw someone showing-off in a car that made this sound.
BTW, mine DOES NOT do this. Its 100% stock, except for the rims.
Old Apr 7, 2002 | 06:38 PM
SonnyinVA's Avatar
SonnyinVA
i have to agree with most of the guys... the gurgling is something that is COOL and lots of people spend lots of money to get it... and is to be expected while decellerating with it still in gear especially at higher RPM's. the popping sound is another story.... you shouldn't be getting a loud "POP" ... maybe just a low gurgle alternating with a little bit louder gurgle. Are you sure it's the stock exhaust?
Old Apr 8, 2002 | 10:27 AM
Torre's Avatar
Torre
Default Re: poping when I down shift (SonnyinVA)
Sonny, I agree.
Its the "pop" that I am talking about.
Old Apr 8, 2002 | 03:52 PM
Sliding's Avatar
Sliding
Mine is also poping, but it started when I took cats off.
Old Apr 8, 2002 | 10:44 PM
BILLY D's Avatar
BILLY D
CJ454: My bike poped thru the pipes because it was running to rich. I put in a smaller low speed jet and that clered it up. If it spit thru the carb then it would be running to lean and I would have to richen it. The ECM does shut down the ejectors when you decellerate to conserve fuel. I would be supprised if yours wasn't shutting down the ejectors. An air leak such as air leaking into the exhaust manifold or pipes could also cause pops since that air would help ignite any unburned fuel. Let us know what you find. Popping thru the pipes is not normal.
Old Apr 9, 2002 | 08:34 AM
CJ454's Avatar
CJ454
Thanx for all the good ideas. I hope to take it to the shop this week. Or the first of next week. I hope it is not a $$$$ item...
May be I shold change the exhaust out then I would have an excuse for it poping :D
CJ :flag :chevy
To poping when I down shift
Old Apr 9, 2002 | 11:15 AM
EvanZR1's Avatar
EvanZR1
C4 of Year Winner (performance mods) 2019
It's fairly normal on the 92s when they are cold. As someone else stated it is mostly due to the "batch" fuel delivery system. When you let off the gas there is unburnt fuel making it's way into the exhaust system where it is igniting, thus causing a "pop" or backfire. It's worse when cold because the computer is running "open loop" which doesn't use any sensor feedback, thus it's just dumping a preset rich fuel mixture into the engine. The stock exhaust system will mostly mask this, but not completely. You should hear what mine sounds like with muffler eliminators! I was slowing down under an overpass right after leaving work one day, and the darn thing popped so loud I thought someone had just fired a howitzer next to me. :eek:
Old Apr 10, 2002 | 12:40 AM
daves87's Avatar
daves87
Default Re: poping when I down shift (EvanLT1)
Right on!!! Not to worry. Music to the ears!!! Now on the other hand if its signifigant backfire thats another story. The gurgling can also be caused by minor reverse compression upon letoff of gas.. again not normally anything to be concerned with. IMHO
:cheers:
[Modified by daves87, 4:42 AM 4/10/2002]
Old Apr 10, 2002 | 10:31 AM
Torre's Avatar
Torre
Default Re: poping when I down shift (daves87)
Music to your ears????
Yea, I like it when my brake pads are all the way worn and you can hear the metal on metal grinding. It sounds so cool!
