outside air temp sensor
Old Dec 1, 2010 | 06:03 PM
Preacher94's Avatar
Preacher94
Default outside air temp sensor
I just changed my water pump and everything is working great except that on my AC control head (it is the automatic system), the Outside Air Temp now reads a constant 51 degrees. It is 80 degrees here in Orlando today. Is there any way to reset this? I have disconnected the battery, but that doesn't do anything. I could be the sensor, but it seems suspect that it failed after the water pump job.
Any thoughts would be appreciated. This is a 1994 base model.
Old Dec 2, 2010 | 01:43 PM
sailorsteve's Avatar
sailorsteve
Try driving at 25+mph for at least 3 minutes to reset the circuit.
Old Dec 2, 2010 | 01:51 PM
aklim's Avatar
aklim
I had that problem in summer after a car wash. Could be that there is residual water there that might cause a problem.
To outside air temp sensor
