What am I missing?
Old Dec 1, 2010 | 08:10 PM
joshwiles's Avatar
joshwiles
Default What am I missing?
Hey guys, so when I got my 84 corvette, I didn't have the crossfire injection cleaner on top, instead it had dual round air filters. Also the smog pump and system was unhooked. As well as the EGR system, the solenoid is completely gone. On the exhaust manifold there is a pipe sticking up on both sides. What are these pipes and where did they connect. Also, what all is required to restore the AIR system and is it even necessary? I know the EGR helps with gas mileage, does the AIR system help as well? Thanks
Old Dec 1, 2010 | 08:41 PM
383vett's Avatar
383vett
Those pipes provide warm air to the air cleaner. Helps with drivability when the motor is cold. The air system (pump) injects air into the exhaust manifolds when the motor is cold to help with emissions. That is not really needed except for emissions because it doesn't do anything after the motor is warmed up. The egr dilutes the intake charge with exhuast gasses and can help decrease detonation.
Old Dec 1, 2010 | 09:36 PM
joshwiles's Avatar
joshwiles
Thanks! So in theory, the pipes from the manifold are best disconnected in warmer areas bc of the hot air vs performance? And any idea if a chevy truck tbi egr solenoid would work on my car?
Old Dec 2, 2010 | 11:02 AM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
The EGR doesn't improve gas milage. Its there to reduce NOx emissions. If you don't have to pass a smog check, don't worry about it.
Old Dec 10, 2010 | 01:06 PM
CFI-EFI's Avatar
CFI-EFI
Originally Posted by paul ruggeri
the egr doesn't improve gas milage. Its there to reduce nox emissions. If you don't have to pass a smog check, don't worry about it.
the egr does help fuel mileage! That isn't it's purpose, but it is definitely a side benefit.
Race on!!!
Jim
Old Dec 10, 2010 | 01:33 PM
cv67's Avatar
cv67
St. Jude Donor '05
Well well well, look who stopped in....
Good to see you stop in Jim
To What am I missing?
