Need help locating fuse link H
Old Dec 2, 2010 | 10:33 AM
hirambulldog62's Avatar
hirambulldog62
3rd Gear
Default Need help locating fuse link H
I have an 85 corvette has the 4+3 manual trans it has been sitting for 3 years. I drained the tank replaced the fuel pump and screen replaced the fuel filter, flushed the tank and lines and replaced the fuel pump relay. Now I don't have power to the relay, the pump, the fuel pump fuse, the oil pressure sinding unit or orange wire circuit 340. I found on alldata that there is a fuse link H thats controls this, but can not locate it. Does anybody know where this fuse link is located.
Old Dec 2, 2010 | 10:57 AM
Muffin's Avatar
Muffin
My 85 FSM says: " LH rear of engine compartment, near battery." Diagram shows a red wire going in and an orange wire out. The orange wire is circuit 340. FYI circuit 340 is the power feed for your Burn off Module.
Old Dec 2, 2010 | 12:06 PM
hirambulldog62
3rd Gear
Thanks for the info, I'll try and find it tonight
Old Dec 3, 2010 | 09:38 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
From my 86 FSM
Old Dec 3, 2010 | 10:52 AM
hirambulldog62
3rd Gear
Thanks for the help, I found it. It was still good, tested my ECM it was good, I had lost ground to the ECM, everything works now car runs better than ever
Thanks again for the help
To Need help locating fuse link H
