1991 no start
Old Dec 3, 2010 | 08:19 PM
mikebassman's Avatar
mikebassman
Default 1991 no start
I entered diagnostic thru the alcl by jumper a and b to see ECM codes it just continued to flash 12 . I then jumpered g and a to see ccm codes it flashes c41 and h41 which I think is Loss of ECM data link. Then under #4 it flashes --- and err
What would cause this could it be loose connector or bad module (s) and where in the car is the ccm thanks mike0554@aol.com
Old Dec 3, 2010 | 09:07 PM
vetteoz's Avatar
vetteoz
http://forums.corvetteforum.com/1574977144-post3.html
Old Dec 3, 2010 | 09:18 PM
rodj's Avatar
rodj
http://www.digitalcorvettes.com/foru...5&postcount=17
http://forums.corvetteforum.com/1554492041-post15.html
http://forums.corvetteforum.com/1554993058-post25.html
http://forums.corvetteforum.com/1555985163-post33.html
Old Dec 9, 2010 | 02:48 PM
mikebassman
got busy checking grounds and found the braided strap that goes from g101 to g104 is broken leaving fuel pump relay ,ECM and a host of other things with no ground .I dont understand how the car was running at all ,unless there was something shorted to ground and it was a back feed situation and now it is not shorted leaving afore mentioned items ungrounded. I have not fixed this yet to see if this is my no start problem but reguardless it has to be fixed first. then Ill tackle the serial data line . one thing i mentioned in my first thread was that my tach went all the way over when the car first started then went to zero i notice now that it does not move ,after reading some threads and a early suggestion that the distributor module might be bad I an going to check that.problem is its been so cold here i havent been able to work on it ! yes it broke down in my brothers driveway and his garage has a C3 in it.
To 1991 no start
