93 corvette wheel offset...
Old Dec 8, 2010 | 04:31 AM
ICANTDR55's Avatar
ICANTDR55
Default 93 corvette wheel offset...
I want to buy some weld draglite wheels for my 93 but i dont know what the wheel offset is. Can someone please give me the wheel size i will need want to go with a 15" rims 50 sidewall.
Old Dec 8, 2010 | 06:50 AM
rodj's Avatar
rodj
Front 17"x8.5" 56mm (6.9" backspacing)
rear 17"x9.5" 56mm (7.4" backspacing)
Old Dec 8, 2010 | 12:45 PM
ICANTDR55's Avatar
ICANTDR55
can i use a 15" rim with a thick sideall
Old Dec 9, 2010 | 04:10 PM
rklessdriver's Avatar
rklessdriver
You can run 15" wheels - but your going to have grind on the rear brake calipers... specifically the "raised fins" that are located on the outside top edge.
If you have the 13" J55 front brakes you'll be forced to run 1/8" spacer to get a 15X3.5" or 15X4" wheel away from the caliper. If you have the 12" base front brakes no spacer should be needed.
Will
To 93 corvette wheel offset...
