c4 tremec trans question
Old Dec 4, 2010 | 10:32 PM
Gary Oates's Avatar
Gary Oates
4th Gear
Default c4 tremec trans question
Does anybody have a tremec trainsmission in a 85 corvette. If so do you have any upward movement of the shifter when starting out or in between shifts?
Old Dec 4, 2010 | 11:37 PM
427c4vette's Avatar
427c4vette
I have a TKO 600 in an 85 and have not noticed any movement upwards of the shifter. I can't say that there is absolutely none but I can say if there is any it is not enough for me to have noticed.
Old Dec 5, 2010 | 12:42 AM
rodj's Avatar
rodj
Check C Beam bolts.
When loose or holes in beam elongated ( common on stick cars ) it allows the rear of trans to lift
under load or change of load ( shifting )
ZF Doc beam plate may be in order
http://www.zfdoc.com/c4beamplate.htm
Old Dec 5, 2010 | 10:07 PM
Gary Oates's Avatar
Gary Oates
4th Gear
Thanks for information I'll check into c brace.
Old Dec 5, 2010 | 10:08 PM
Gary Oates's Avatar
Gary Oates
4th Gear
Are you running a stock engine.
Old Dec 6, 2010 | 08:48 AM
fxmcc's Avatar
fxmcc
2nd Gear
tko 600 in 86 vert - no movement / solid.
Old Dec 7, 2010 | 07:11 PM
HlhnEast's Avatar
HlhnEast
Didnt LD85 have the Tremec conversion in his? Havent seen him around in a while. He never mentioned any movement but really praised the swap.
To c4 tremec trans question
