1985 MAF Interchangeability
Old Dec 5, 2010 | 06:49 PM
btr85vette's Avatar
btr85vette
Default 1985 MAF Interchangeability
On a 1985, is a 1985 MAF the only one that will work, or will a later year work also.
Old Dec 5, 2010 | 09:07 PM
Muffin's Avatar
Muffin
A quick check of Ecklers shows:
1985----- 35290
86-89-----35291
I have no clue what the single digit difference means. Wonder if it has something to do with the switch from a burn off module to relays?
Took a look at Corvette Central, Granatelli MAF fits 85-89. CC also offers a reman MAF for 85-89.
Old Dec 6, 2010 | 12:04 AM
samsonb's Avatar
samsonb
It could have something to do with the tune. 85 is tuned different with a different fuel pressure and different pound injectors.
Old Dec 6, 2010 | 01:01 AM
856SPEED's Avatar
856SPEED
interesting........mine has bigger injectors, more fuel pressure, and a different tune, but OEM, original MAF......NO problems.......may have to look into this....you may be right, I personally don't have a clue.....
Old Dec 6, 2010 | 01:11 AM
samsonb's Avatar
samsonb
I'm just guessing as to the difference between 85 and 86-89 with regards to them having a different MAF.
85 also uses a different fuel pressure regulator diaphram from the factory. As it is set up to run lower fuel pressure than 86-91.
Old Dec 6, 2010 | 12:16 PM
btr85vette's Avatar
btr85vette
Will a MAF from an 85 - 89 F-body work also, or is this a completely wrong calibration.
Old Dec 6, 2010 | 12:23 PM
Muffin's Avatar
Muffin
Another quick check, this time from Rock Auto. The 88 Firebird and Corvette use the same MAF.
Old Dec 6, 2010 | 01:48 PM
WW7's Avatar
WW7
From the reading I have done it looks like the 86-89 maf from the Firebird and Camaro both will work on the 86-89 Corvette..The numbers on the Firebird and Camaro Bosch mafs are #0280213004 and #0280213002..WW
To 1985 MAF Interchangeability
