tran shift quest
Old Apr 6, 2002 | 10:38 PM
DADDY D's Avatar
DADDY D
Default tran shift quest
i have an 86 vette
just got back from the track i ran an 8.51 but i manually shiftted my car and when i shifted from first to second i shifted then a couple seconds later the car shifted i have adjusted my tv cable but i got the same results. any ideas on what is going on here. did run a 8.30 testing a little nos dry shot
Old Apr 6, 2002 | 11:25 PM
KYVette90's Avatar
KYVette90
Default Re: tran shift quest (DADDY D)
Sounds normal to me. When you manually shift an auto it's not an instant shift.
Old Apr 7, 2002 | 05:15 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
You need a shift kit to quicken and firm up those shifts.
When I manually shift my A4 above 5k RPM it realy hangs on the 1-2.
Old Apr 7, 2002 | 02:12 PM
DADDY D's Avatar
DADDY D
Default Re: tran shift quest (65Z01)
I have a superior shift kit in it.
Old Apr 7, 2002 | 10:48 PM
DADDY D's Avatar
DADDY D
would the governor have anything to do with this.
Old Apr 7, 2002 | 10:50 PM
NoWorries's Avatar
NoWorries
I dunno why you got the delay, but my guess would be a sticky or stock governor. Changing the weights(talk to a tranny shop about how much) might give you the results you're looking for.
Nice time btw, :cheers:
Old Apr 7, 2002 | 10:53 PM
DADDY D's Avatar
DADDY D
Default Re: tran shift quest (NoWorries)
when you say tranny shop are you referring to the place i got trans done or is that a place on the web or somewhere i can call
Old Apr 8, 2002 | 09:18 PM
DADDY D's Avatar
DADDY D
any other suggestions
To tran shift quest
